Choke on Start up not working - 360 | FerrariChat
Discussion in '360/430' started by fabo, Jul 16, 2014.
  1. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    I have noticed lately the auto choke is not working on start up?
    It's winter here at the moment and it's cold so I would imagine it should be coming on more now than ever
    Any advice please
  2. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Choke on a modern car -- I don't think so. Those went the way of the dinosaur years ago. All done by computers these days based on water and air temperatures to richen up the mixture.
    Alan
  3. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    My bad
    So why do u think the computer does not idle high at start up anymore ?
  4. vrsurgeon
    vrsurgeon F1 World Champ
    16,540
    Charleston, SC
    Curt
    The 360 has a higher idle than the 800 that I'm used to. Mine does go up by 200 RPM or so when cold.
    Check the sensors.. English Rebel on another post noted the water temperature sensor in front of the oil filter. Is the temp gauge working well? Computer should sense the engine is cold and increase the RPM, mixture, etc.
  5. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Okay now I see what you are asking -- cold idle. Mine idles at 1200-1300 RPM until warm (not sure what that temperature is) and then drops back to 1000 RPM. As Curt says it could be an erratic or bad water temperature sensor. What is your water temperature gauge reading when fully warmed up on a hot day but not idling in traffic?
    Alan
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The coolant temp sensor that the ECU uses to control engine functions is not the one that feeds the temperature gauge. This one needs to be read using a scan tool like the SD2.
  7. tazandjan
    39,174
    Joe- What you are describing is the very common rough start with late model Ferraris that seems to be caused by injector bleed-down, sometimes cured with a can of fuel injector cleaner like Techron. Try waiting a few seconds after the check ok lamp illuminates and see if that helps. If not, a double start nearly always works. Normal start, shut her down immediately when she catches, and restart. Should work normally then. Your tech may be able to find a fix.
  8. MufflerMan
    MufflerMan Formula 3
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    I may be incorrect on this, but I thought the higher idle on start up was part of the emissions control system. Colder engines are dirtier to the air quality than warm ones and I thought the higher idle was part of that.
  9. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    Interesting
    My car on start up used to idle at 2200rpms for around 1-2 minute than come down to 1200rpms. That was in summer
    Now it is winter the start up idle is much less, around 1200rpms. I would of thought being colder it would need to idle higher until it warms up?
    thoughts?
