Choosing a lithium battery | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by plugzit, Dec 4, 2011.
  1. staatsof
    96,450
    Fuggetaboutitland
    Bob
    You missed the "disconnected" part of my question, so zero drain but just sitting there.
    I ask because I have several cars which have cut-off mechanisms and one or two of them "might" be a candidate for battery like this but not if it's expensive, a PITA to keep charged and also a potential fire hazzard.
    I have no power in the storage locations either.
  2. staatsof
    96,450
    Fuggetaboutitland
    Bob
    Thanks.
  3. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    #53 marcov, Jun 29, 2013
    My PC925 Odyssey died a few weeks back as a result of over-charging with a smart charger (not so smart). I liked the PC925 (26lbs) and has never let me down, but I was tempted to try the PC680 (15.4lbs) to save some weight. I went shopping at my local battery store, and the sales person mentioned that the PC680 was used on some motorcycles and that there were some Lithium motorcycle batteries that were substantially lighter….
    As a result I left the store without buying a replacement battery and started researching about Lithium batteries. As expected not all Lithium batteries are manufactured to the same standards. And, to complicated things the Lithium batteries have a completely different chemistry, and discharge profile, than the traditional lead acid batteries. Consequently, ratings are marketed differently, not to mention the cost of Lithium battery is substantially more than a conventional battery. However, if I can save 20+ lbs at the back of a 348 it is money well spent.
    After doing all my researched I decide to buy the Antigravity YTX12-24 Battery “;http://antigravitybatteries.com/ytx12-24/” with 720 Cranking Amps at 5Lbs… (That is 21lbs less that my current the PC925 and 10.4lbs less than the PC680.
    Prior to installing the battery, I did a few modifications to the current charging system. First, I removed the positive bullet connector under the air filter. This should reduce the overall resistance and improve reliability.
    Next I replaced the heavy lead battery terminal connectors with lighter AC Delco copper terminals style connectors. This allows for an easier connection to the YTX12-24 Battery and saved and additional 1.2lbs.
    While waiting for the battery, I also decided to rebuild my alternator tensioned. I have never liked this type of tensioner system. I machined a new tensioner from billet 6061 Aluminium and managed to reduce the mass by ~.5lbs. Over the winter, I will manufacture a new alternator bracket to allow the alternator to swivel with a screw type tensioner. This will eliminate the roller type tensioner completely and remove further mass and parasitic drag.
    Next I built a new battery bracket to contain the YTX12-24 Battery.
    The car fired up great!
    [ame=http://www.youtube.com/watch?v=6MeY0iu0dRM]Ferrari 348 with 24 cell Antigravity Battery - YouTube[/ame]
    Over the next few months I will continue to monitor the modification and proved status updates.
  4. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    After a few days of driving with the new battery I have a few positive observations. First, the battery voltage seems to be steady and the car starts very well every time ( just like if I had a fully charged battery). With the reduced mass the car feels lighter and seems to accelerate better. However, this is a very subjective seat-of-your-pants indicator.
    One observation, that is very apparent, is that the car does not seem to overseer as much. When I took the car on a few twisty roads, including a tight roundabout , the back end was definitely more stable and planted to the road. So far, this is a great performance modification.
  5. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Great news!
  6. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    How did you replace the bullet connector and what copper connectors did you buy?
    Kai
  7. boxerman
    boxerman F1 World Champ
    19,994
    FL
    Sean
    Only 25 AH though 720 CCA.
    Another alternative is the Shorai with 36 Ah and 550 CCA.,
  8. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    18,002
    wisconsin/chicago
    bo
    I use lithium batteries for my radiocontrolled planes/helis.
    You definitley need special charging equipment/voltage cut offs/indiviual cell balancing software.
    Lithium batteries are delicate, and do not take abuse. Discharge it once, and its toast. Overcharge it once, and it goes up in flames.
    Bo
