Chrome exhaust | Page 3 | FerrariChat
Chrome exhaust
Discussion in '296' started by Adrian-a, Feb 26, 2023.
  1. FTRAK1
    FTRAK1 Karting
    Mar 17, 2020
    105
    Bill Schwartz
    I have a chrome exhaust on my 296GTS and it gets stained and can't be cleaned. Get black. Don't even consider chrome as an option.
    Dino_Argento likes this.
  2. ATLBond
    ATLBond Formula Junior
    Oct 30, 2021
    311
    Atlanta
    SR
    Its atrocious that Ferrari gives Chrome as the default option. Chrome exhaust gets stained / soiled so easily, and the worst part is that it is in the middle of the back, above tag display, compared to being placed at the bottom on either ends. I am making sure my GTS will have the black exhaust.
  3. FTRAK1
    FTRAK1 Karting
    Mar 17, 2020
    105
    Bill Schwartz
    Actually even if it can be cleaned, you would have to do it fairly often. I'm wondering if I could get the thing painted black. Anyone try that or have ideas about how to do something like that?
  4. ATLBond
    Oct 30, 2021
    311
    Atlanta
    SR
    I explored powder coating with heat resistant formula that can stand the temperature of exhaust. The cost to getting thew exhaust piece out of the back bumper assembly was ridiculous, and my GTS is anyway coming, so I decided not to do it. When you open the engine bay glass cover, you'll see lot of high voltage circuitry running all around. No shop, other than a Ferrari dealer, will touch it.
  5. KL runner
    KL runner Formula Junior
    Jul 25, 2023
    771
    Not in US
    There have been other posts that have said they tried to paint it and it failed .
    The black can still get a residue but it is harder to see . I believe that wiping the exhaust reasonably often wil be needed .
    I have black on my GTS order
  6. mkraft3003
    mkraft3003 Formula 3
    2,406
    Tampa, Fl
    Won’t work. Tried and I ended up ordering the black tip.
  7. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,323
    michigan
    john
    OK all you exhaust OCD types, it's time to try an experiment.
    Is it possible to use some sort of tape in the exhaust to bypass 'stain' cleanup?
    Armed with some random tapes, we're going to find out.
    Started with basic Scotch clear tape in the wide width. Also considered duct tape, and wide black masking tape.
    So far here's what I learned.
    I made a paper template thinking a pattern would help, but that wasn't necessary.
    Here are the results. Once I put some miles I'll remove the tape and replace it. It's not readily visible, and I doubt anyone would notice. But, you never know.:rolleyes:
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    BigJay2050 likes this.
  8. FTRAK1
    FTRAK1 Karting
    Mar 17, 2020
    105
    Bill Schwartz
    So Mkraft - didn't know you could order one to replace the existing chrome. What did it cost to buy the replacement and have it installed? I'm also wondering if it makes sense to simply let the exhaust cover the chrome (not try to clean it). Maybe with enough coverage it will look black anyways!
  9. mkraft3003
    2,406
    Tampa, Fl
    Yes, it is just the tip and either comes in chrome or black. I think the part was $3500 and the installation was 4 hours ($1000). They have to remove the entire rear bumper as it is held in by clips from the inside.
  10. FTRAK1
    FTRAK1 Karting
    Mar 17, 2020
    105
    Bill Schwartz
    Thanks!!
  11. PieGre
    PieGre Karting
    Jan 9, 2019
    179
    Luxembourg
    PG
    I've never regretted having bought the black one, 15000 km on the clock, no problems, as new.
  12. FTRAK1
    FTRAK1 Karting
    Mar 17, 2020
    105
    Bill Schwartz
  13. SV488
    SV488 Rookie
    Jun 4, 2021
    14
    Sesha Varadarajan
    Has any one seen the twin tip Novi option in person? Thoughts if any would be appreciated.
    Sent from my SM-S908U1 using FerrariChat.com mobile app
  14. FTRAK1
    FTRAK1 Karting
    Mar 17, 2020
    105
    Bill Schwartz
    I have a GTS with a chrome tip which I hate. I'm having it replaced with the black tip which they quoted at about $2500 and that does not include installation. I believe that will add another $1000, They have to remove the rear bumper to install it. The mesh screen on the Novitech will require installation by someone and that will add to the cost, making that total over $3000 as well. I chose the black Ferrari tip because my dealer would not install the Novitech and also to keep the car exclusively Ferrari. I really like the look of the Novitech and would have done that even though I haven't seen it in person. Assuming you are good with non-Ferrari parts, I don't think you can go wrong with that look. .
  15. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,323
    michigan
    john
    Just to close the loop on this experiment, it doesn’t work. Too much heat.
    Polish it would appear is the only solution.
  16. FTRAK1
    FTRAK1 Karting
    Mar 17, 2020
    105
    Bill Schwartz
    The best solution is to lose the chrome and buy the black - either Ferrari or Novitech. My dealer said they will never order or allow anyone to order the chrome one again.
