Cigarette lighter question | FerrariChat
Discussion in 'Mondial' started by syata, Oct 2, 2017.
  1. syata
    syata Formula Junior
    Feb 23, 2017
    427
    Can some please post pictures of the inside of the cigarette lighter pod that is in the center console and the lighter itself.
    I recently bought a 1988 Mondial 3.2. The cigarette lighter is not the normal size; it is skinnier than what modern cars have.
    I purchased a replacement lighter that should fit the lighter but it does not fit it the pod. The lighter fits in the 12 volt socket in the glove box. Not sure if the metal ring in the pod needs to be removed.
    When I pull on the pod the bottom gets red and hot so the pod in the center console seems to work.
    Thank you.
  2. Cadillacbart
    Cadillacbart Formula Junior
    Nov 26, 2013
    436
    Denver, CO
    You have the original cigar lighter in your Mondial, and that functions as you described. Pull it up, it gets hot, you stick your cigarettes in and smoke away. Does not work as an accessory socket. You'll need to retro fit an outlet in the space. You will have to pull the switch panel from the console to get to the backside to properly install it.
    See this thread for folks that have been there:
    http://www.ferrarichat.com/forum/threads/mondial-cigarette-lighter-auxiliary-power.344077/
  3. syata
    Feb 23, 2017
    427
    Thank you. So was there a cover when not used?
  4. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    I don’t think so...
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,941
    Isle of man- uk
    I removed the rear cig lighter in the central console and replaced it with an aux power socket- that leaves you with the forward lighter. The complete aux power socket is on Amazon if you want to do this mod
    TGIF and paulchua like this.
  6. FamilyCar
    FamilyCar Formula Junior
    786
    Seattle, Wa
    Peter Goodall
    I wonder if someone already swapped out a modern lighter into the glove box, because the original socket in there is for the trouble light and is much smaller than a lighter. The cigarette lighter does not have a cover. My car does have a typical lighter socket under the dash to the right of the steering column, which was probably added later, but you may look there and see if someone did that to yours as well.
    paulchua likes this.
