CIS fuel line replacement | FerrariChat
Discussion in 'Technical Q&A' started by 85MondialQV, May 5, 2021.
  1. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    On my 85 QV my fuel line going from the meter/fuel distributor to the injector on cyl #4 broke. Any place to find a replacement? I looked everywhere and came up with nothing. Thanks everyone!
  2. lopena
    lopena Formula Junior
    766
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
  4. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    Where it screws into the injector. I was spinning the nut about the injector and the fuel like was a bit corroded and the line twisted which ruined it. The nut fitting and line was jacked. Looking to replace the full line if possible. And might as well do them all if I’m there. Do one, then do the rest. There all 35 years old.
  5. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
  6. lopena
    766
    Replacing the black plastic lines is a fiddly job requiring patience and a special tool (readily available from Unobtainium Supply), but it’s well within the scope of a mechanically-inclined owner.
    Finding the metal lines may be a challenge. I don’t know if they are readily available new...you may have to resort to a used set off ebay (where they show up infrequently).
    good luck,
    Alan
    N.J.
  7. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    I wonder if I’m better off going to a hose shop and having them make me custom braided lines for all 8
  8. lopena
    766
    Matt:
    Yes...you can probably cobble together another way to get fuel from point “A” to point “B”. I would think that the internal diameter of any alternative hose you use should be identical to the factory hoses to keep the fuel flow within design parameters.
    One other thing you might try: the metal lines have a lot of slack in them (in the form of loops). Maybe you can unwind one of the loops on the damaged metal line, clip off the last few inches and resolder the nipple back onto the line. Maybe someone else on this Forum has done this? Just a thought...
    good luck,
    Alan
    N.J.
  9. dave80gtsi
    dave80gtsi Formula 3
    1,948
    Ohio
    Dave Meredith
    85MondialQV likes this.
  10. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    Those look great. Did you I’ve a hose company do them. 2 questions. Does Hose I.D. Matter? And does length matter? Did you get them all the same length? I need help!! Hahahahaha
  11. dave80gtsi
    1,948
    Ohio
    Dave Meredith
    No, this was a total DIY. Goodridge hose and fittings. Every line is unique in terms of length and fittings on each end. Hose I.D. and line length are not critical.
    Very fussy to do, with lots of 'not quite right' lines which ended up in the bin. If I had to do it over again, I probably wouldn't. Better for you to repair / replace your damaged single fitting with OEM.
  12. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    Oh didn’t even see this message before replied on the DM. Thanks you for the info
  13. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,742
    Argent/Brasil
    Guido
    Eurospares.uk has them but you have to ask....and pricy.
  14. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    I'd rather keep the line stock. This being said if he wants to make a custom set of lines he can salvage fittings from a VW or Mercedes and then make his own lines. That's what I did a s a temporary fix for my return line. I did not like the shiny look and thickness of the hose, but at least the car was not stuck any-more.
  15. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
  16. dave80gtsi
    1,948
    Ohio
    Dave Meredith
  17. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    I’ll do that. I’ll order 8 maybe 10 in case some get messed up. Thank you for your helping me. I talked to Larry Fletcher on the phone and he was helpful as well.
  18. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
    Length isn’t critical? I saw yours are all custom lengths Dave. That doesn’t cause any issues or running rough?
  19. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    Not critical as long as you use the proper polyamid tubing.
    There were problem on Porsches, that used tubes with thinner walls, but the tubing was much longer than on our cars.
    On our cars same material but thinner wall did not cause issue. If you take something totally different your mileage may vary?
    Worst case you adjust the individual output of each injectors on the distributor.
  20. mwr4440
    58,067
    Bavaria, The 'Other' Germany
    Mark W.R.
    #20 mwr4440, May 18, 2021
    Lesson Learned.
    Removing the Fuel Lines from the Injectors is ALWAYS A TWO WRENCH Job.
    ALWAYS.
    Sorry for your misfortune.
    Prepare to pay +/- $100 per line IF and WHEN you can find them.
    Ferrparts was selling an incomplete set (7 of 8 IIRC) on eBay a week back.
    CHECK with them.
    You might get lucky.
    To ALL,
    Those 30+ year-old black plastic lines are seriously potential TIME BOMBS.
    REPLACE THEM. I had 8 SERIOUS cracks in mine I could NOT SEE or FEEL until they were removed.
    It is an afternoon's job and quite easy to do IF you also have the tool.
    GordonC and 85MondialQV like this.
