Clean OEM headers | FerrariChat
Clean OEM headers
Discussion in '348/355' started by lotusk, Nov 10, 2013.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Hi
    Am trying to clean off the brown whatever it is covering my headers.
    I am using engine degreaser and a scotch pad to reveal the shiny finish under the brown stuff...it's hard going though.
    Anyone know a better method?
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'm pretty sure that is just discoloration from heat. Scoth brite is probably your best option and perhaps a wasted effort since they will probably turn again soon.
  3. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    What's happening with the heat to turn them brown?
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
  5. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Be nice Johnny
    No need for that tone sonny
  6. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Oh forgot ...you're the rubbish that rubbishes the gold connector kit.
  7. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    It's just a suggestion. Don't read more into it that what was typed. If it was meant to be sarcastic I would not have posted the link for you to read.
  8. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Because the GCK is just that. Your opinion of me is irrelevant.
  9. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Lotusk,
    Muriatic acid will instantly remove the oxide from SS headers with no effort. It will also remove rust. Just be careful to prevent it from getting on most anything else as its very caustic to most but not all materials (won't harm plastic or glass). Vapors are caustic as well so, if you choose to try it, use in a well ventilated area.
  10. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    So, the best method would be use rubber gloves as the they won't melt or get on your skin. Also, use a plastic brush or scotch pad. It will eat through organic materials and will damage metal if it stays in contact. Wipe on, rinse off.
  11. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Thanku
    Sounds good
  12. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    I have some before and after pictures of the heat shields on my header thread, F355 Headers by Stainless Headers. During the header building process I had asked Chris if he could clean up the old shields. It seemed like a shame to put these brown, rusty old shields on brand new custom made headers. I think that he did a nice job. I didn't ask what he used to clean them though. You could always give him a call.
  13. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    #13 gothspeed, Nov 10, 2013
  14. ClydeM
    ClydeM F1 World Champ
    12,086
    Wayne, NJ
    Clyde E. McMurdy
    A product available at your local hardware store would be "Wink"...often used to get rid of rust stains on porcelain toilets. I'll bet it'll work here too.
  15. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Jeez
    Did u have to show me those amazing headers of yours?
    Mine look totally awful.
    Internally they were rebuilt well (i hope) by QV of london, uk....and the heatshields were welded back on....but yours show the seam complete whereas mine have bits nibbled away probably where QV had to rip them open.
    How many miles have you driven with them on the car and have they turned brown yet?
  16. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    The headers will be going on shortly when my major is complete. The reason you see the seams was because the primary pipes are slightly bigger than OEM. OEM's are 1.57 and my headers are 1.625. So in order to reuse the factory shields they had to expand them a little. Also, the shields came off of the second set of headers which my new ones were copied from. The shields were not cut on the seam so the guys had to do some custom fabrication.
  17. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    I am sure the shields will turn a golden brown once they get hot. I don't mind that. I didn't like the areas on the shields that had surface rust on them.
