News
Clean those wheels, PLEASE!
Discussion in 'Technical Q&A' started by DANCER308, Mar 31, 2010.
  1. DANCER308
    DANCER308 Formula Junior
    934
    KY
    Dan
    #1 DANCER308, Mar 31, 2010
    When I bought the '79 308 GTS, it looked pretty good for 31 years old, but the wheels needed help. These are after market wheels. I had cleaned aluminum wheels before, by hand, and it was a lot of work. I wanted to clean these, but this time I was going to use a drill with sanding, buffing and polishing disks and pads. These are 2 piece wheels, with the center piece clear coated. The clear coat was remove with a paint stripping liquid. I started with 100 grit disks to remove the machine grooves and corrosion, switched to 220, 400 and finally 600. Next I used a 600-800 grit 3 in. hook and loop scuff brite buffing pad. This removes most of the scratches left by the 600 grit sanding disk. Next I used a 1200 grit scuff brite pad with Blue Magic Liquid Metal Polish. The more times you use the pad/polish combination the shinier it gets. Next I used the polish with a buffing wheel (Harbour Freight). Followed this with Tripoly and White buffing compounds. I polished the center of the wheel to a chrome finish and the outside to just a shine. I did not want the whole wheel to look like chrome. Painted the bolt heads black, changed the background from gold to flat black. One wheel down, three more to go.
  3. cletus
    cletus Karting
    Feb 7, 2006
    249
    nice work!
  4. carwasher
    carwasher Rookie
    Nov 30, 2006
    17
    Central PA
    Jon Rose
    Lot of work, but looks great.
  5. DenisB
    DenisB Formula Junior
    Jul 21, 2007
    426
    Cape Cod Ma.
    Denis B.
    I really like the contrast, Looks great
  6. dave80gtsi
    dave80gtsi Formula 3
    1,491
    Ohio
    Dave Meredith
    #5 dave80gtsi, Apr 1, 2010
    Nice to see that I am not the only vintage Gotti fan here!
    Here's mine. What I was seeking was a subtle contrast between the outer polished rim and the inner spokes. So I had the spoke section bead blasted to clean, leaving a slightly "pebbly" matte finish. I then had these center spokes clear anodized for protection.
    When I take the car with these wheels to local Ferrari shows, I always get lots of positive comments.
    Cheers - DM
  8. dave80gtsi
    1,491
    Ohio
    Dave Meredith
    #6 dave80gtsi, Apr 1, 2010
    By the way - this might also interest you - a 15" one-piece Gotti clone, spotted on a Firebird at a local hot rod show recently.
    The center cap notes "American Racing" brand, which may or may not match the wheel manufacturer. Maybe he just stuck these caps on because they were lying about handy?
    It's a very convincing replica at first glance, but if you look very closely you can spot the subtle differences. 15 pcs. of dummy wheel rim perimeter bolts, for one.
    Cheers - DM
  9. DANCER308
    934
    KY
    Dan
    I like your contrast also. Great job.
    Dan
  10. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,840
    Mount Isa, Australia
    Pap
    Fantastic work Dan!! :D:D
  11. luv2detail
    luv2detail Formula 3
    Mar 30, 2006
    2,218
    Ventura County, CA
    Jason
    Wow! What a difference. Great work!
  13. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Dan, Dave,
    Nice work on the wheels, well worth all the hard work!!
    Regards,
    Phil.
  14. f355jimv
    f355jimv Formula Junior
    Jan 21, 2008
    685
    Southern California
    Jim
    That is some great detail work!!!!
  15. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,204
    Michigan
    mark s
    ....wow, well worth the work - fanatastic job!
  16. Darryl
    Darryl Formula Junior
    Jan 4, 2006
    390
    Southern California
    Darryl
    You are a true Ferrari owner, well done. Oh I hate to clean the rims, it takes so much time.
    How many hours do you have invested in that one wheel?
    Darryl
  17. RED TESTAROSSA
    RED TESTAROSSA Formula Junior
    Jul 8, 2009
    412
    So. Calif.
    Randy
    Both wheels look great! Nice job.
  18. DANCER308
    934
    KY
    Dan
    The first wheel takes longer due to finding the right combination of sanding disks, pads and polish. Now that I have that figured out, the other wheels will go faster. Probably around 4 hours a wheel. I am also replacing the suspension bushings at the same time.
    I noticed that the car handles much better and is faster with the one clean wheel, can't wait till the others are done. lol :)
    Dan
