Clean512 ..360 coupe project | Page 18 | FerrariChat
Discussion in '360/430' started by clean512, Jun 3, 2020.
  1. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    [emoji106][emoji106][emoji106][emoji95]
    Sent from my CPH2145 using Tapatalk
    clean512 likes this.
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    I appreciate the talk this morning. Got that intake coming and the tune is amazing
  3. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
  4. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    919
    TX
    I was looking at and considering that bumper since it was a hell of a deal but ultimately didn't want to deal with setting up the shipping, congrats on the score
    02360spider likes this.
  5. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    They didn't want to ship either. Its like 4 hrs from me
    RANDY6005 likes this.
  6. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    367
  7. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    I'm curious about that too. I belive most 03 and 04 cars had this. I talked to Trevor and says the tune will be fine. But curious why ferrari changed it
    Some Guy in the sky likes this.
  8. Some Guy in the sky
    Sep 19, 2018
    367
    I have an early 99 as well and am a big fan of the induction noise between 2000ish and 4000 rpm, it sounds almost demonic. That alone would prevent me from changing the intake if it changes the noise.
    Caphill likes this.
  9. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    Don't think it will change the sound but you never know. But all CS cars had this style
  10. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Does it have the machined trumpets inside ?
  11. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    I'll let you know butvi believe they do since those are on the bottom part
  12. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Now Trev360 mentioned the race teams added a spacer between the head and the manifold face/flange for increased performance . I dont think the 10mm or so inlet track length increase made much difference . I think if the correct material was used it created a heat break to reduce the heat soak into the inlet manifold therefore reducing the inlet temperature . It would be interesting to now more about this , as if you are changing your manifold it would be an easy thing to do .
  13. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Same I iknow clean512 is in ca and was looking for a front bumper so I dropped him a line.
    Sent from my SM-G996U1 using Tapatalk
  14. ecarca
    ecarca Karting
    156
    Hong Kong
    Emmanuel
    [QUOTE="duck.co.za, post: 148163777, member: 43973"I think if the correct material was used it created a heat break to reduce the heat soak into the inlet manifold therefore reducing the inlet temperature . It would be interesting to now more about this , as if you are changing your manifold it would be an easy thing to do .[/QUOTE]
    The so called "phenolic spacers". Not sure if it does anything at all, I had one on one highly modified other brand car a few years ago as part as many other mods so I can't tell what that particular part did. I bought the story about heat transfer then, even more so that the car was a turbo so charge air is quite hot.
  15. timwu12
    Oct 31, 2014
    919
    TX
    What exactly is the difference in the intake design? I know there was a change to the vacuum routing at the back but what else is different?
  16. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    Just a small angle at the back side
  17. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    There are actually a couple of reasons to do it.
    No 1 is to reduce the tendancy for turbulence and thus air starvation to a couple of the cylinders at the back in relation to the other 6 at higher rpms. This improves efficiency with more even airflow between front and back cylinders for improved combustion. It doesn't just hit a brick wall at the back.
    The other was more practical, so they could physically fit the engine in later 360 spider variants which is more challenging given the packaging is tighter on Spiders Vs the Modena. This is probably the main reason to do it [emoji3526]
  18. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
  19. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    Oh and I love my stage 2 tune from AV engering and 360trev did a amazing job with it.
    armedferret and 02360spider like this.
  20. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    What mods did he tune for?
  21. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    Beside the 430 maf and the factory CS exhaust and the high flow cats. Are really the only mods are needed at this level. Will see where I go next with him.
    But the magic is in the tune and software where trev does custom exhaust valve maps where the valves open sooner, the readiness is in green, remove the cat monitor and I full elaimtied the cat ecu and probs. Appy the instant torque patch.
    I love just how the car works and feels .its been allmost a year and not one problem with it.
    Thank you Av and trev
  22. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    AndreB, Caphill, veilstylez and 3 others like this.
  23. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
    So it actually doesn't and will be using my 99 bottom part with the top later style. Just had a great talk with trev and he believes the design with the 45 angle on the latter top was the improvement that they didn't need the machined trumpets but ill incorporate both cool parts and have the best of both worlds. Its still a beautiful intake design
    armedferret likes this.
  24. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,125
    Josh @jtcarprojects
  25. DBomb117
    DBomb117 Formula Junior
    Jun 20, 2019
    344
    Connecticut
    Dimitriy
    So from my understanding are they really only called “machined” because of the ported style finish?
