Clean512 ..360 coupe project | Page 23 | FerrariChat
Discussion in '360/430' started by clean512, Jun 3, 2020.
  1. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I some spares needle bearings & white Delrin and gray ones.
    Needle bearings had some stiction not as smooth as Delrin.
    Are going too lube them ?
    clean512 likes this.
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    Which one did you use randy. These ones or the ones with needle bearing
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Scaped needled bearing ones used gray plastic.
  4. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    You are doing one heck of a job my friend !!
  5. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    That looks like Vescanite , steering rack bushes are made from the same stuff , well older cars ( 308 )
  6. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    Coming from you buddy that means alot. Hope the trip is amazing
    RANDY6005 likes this.
  7. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
  8. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
  9. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
  10. Scottslaw
    Scottslaw Formula Junior
    Absolutely awesome pics!
    clean512 and 02360spider like this.
  11. 67bmer
    67bmer F1 Rookie
    3,219
    MD
    Where should the oil temp gauge run? At one point I was wondering if it was connected! It got to where yours is on the first firing checking to see about leaks etc.
    I have just got mine running again, completed four drives, and have been paying very close attention to my instrumentation. It has gotten into the 60's here and my gauge doesn't get to where yours is unless it was idling in the driveway.
  12. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    367
    From the work shop manual:
    '''Under normal operating conditions (i.e., engine running at 6000 revolutions/1'), the oil pressure range must be
    between 5 and 6 bar and the temperature should be about 100 °C.
    Heavy-duty use of the car can raise the oil temperature up to 150 °C. In such cases, the engine load must be
    lowered in order to restabilize the temperature. If the temperature continues to remain high, inspect the
    system components to ensure that they are intact.
    With the engine warm and idling, a pressure lower than 4.5 bar should be considered normal.
    The pressure level is determined by the pre-loading of the spring in the pressure regulating valve (5, Fig. 1) (B
    3.05).'''
  13. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
  14. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    Amazing things coming from supersprint. Now the wait time.
  15. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    veilstylez and 67bmer like this.
  16. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Great plan , like the idea of fabricating the CS deck lid from ally . Do tell us what is coming from Supersprint , headers ?
  17. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    Yes .I reached out to them and they are building me a set that will convert to the oem style exhaust. There headers usually require there cats but didn't want that way. There parts look amazing
    duck.co.za and Flea7 like this.
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,788
    Great choice. The best out there.
  19. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    Mark,
    What's the weight difference between lexan rear lid set up compared to standard glass lid? I have the F430 weight down to 3,100 lbs. trying to get it down to 3,000. Looking to replace the whole assembly with scud set up.
  20. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    I'll let you know in a couple days when my lexan part gets here
    Flea7 likes this.
  21. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    Those headers look terrific!
  22. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
  23. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
    EhellGuapo, DBomb117, AandSC and 3 others like this.
  24. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    919
    TX
    Would you mind telling what material and how much? You can PM me if that works better
  25. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,136
    Josh @jtcarprojects
