I feel the bottom one with the machined Trumpets were a supior design but I bet ferrari realized the cost was more. Then the later top to help with airflow with the slop. The car absolutely rips. If your every in CA come by and drive it.
The tune I'm sure is awsome plus the extra delete for more weight savings I definitely need it in my life. Sent from my SM-S908U1 using Tapatalk
Not much this week but my outside door locks have never locked my car. And when I got my car only had 1 key, not good right. Pulled all 3 out and and my local lock shop rebuild the door locks and cut me a new key. No immobilizer now and works perfectly like a normal car. Cleaning the window tracks and looking everything over. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Did you replace your GlycoShell decal? What about your emissions decals? How/where did you find them?
I got that one from superformance. Can't find the emission ones. If any one can point me into that direction. And if any one didn't notice that is the 430 coolant tank. I like the look of it better then the 360. But matched it with the 360 cs colors
Its been crazy the past month in CA rain and more rain.. but got a little time on modify the dash corners. Little steps. Image Unavailable, Please Login Image Unavailable, Please Login
Made some progress on the dash. Lower is fitting good now. Will need to come up with a bracket for the middle to hold the main weight. But maybe 2 hrs in. I could see a total of 8 to be happy. Some holes need to be moved around and perfected. Definitely not for the average. Image Unavailable, Please Login
Fantastic , that's the first one trial fitted . Not sure about the middle mount as that is a radio pod option and when I received the original ,the pod had already been removed , so I don't know what brackets are required . We have realized that there is a mounting point ( threaded bush insert ) on the passenger side that will be missing on your dash . ( I will include it with Richards dash and you will need to bond it to the inside ) you can see it directly above the speaker hole on this print . I am really excited you are progressing with your install , thank you . Image Unavailable, Please Login
The gap indicated by the arrow , is solved by the factory in the following way (as show in the pictures ) That is what I found under the red alcantara . You can just see your missing mount in my first pic . Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
3 brakets I found that are exclusive to the cs lower dash.main center bracket is the same part number as standard 360. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Sent from my SM-S908U1 using Tapatalk
I didnt have the bottom 3 bolts in on the L side which all lind up. The gap was better then that pic but that is interesting how they did that. Hand built cars and make it perfect in some way.
