Clean512 ..360 coupe project | Page 7 | FerrariChat
Discussion in '360/430' started by clean512, Jun 3, 2020.
  1. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    Flea7, mwstewart, veilstylez and 2 others like this.
  2. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Nice did you score them on ebay I seen a set pretty cheap.
    Sent from my SM-G996U1 using Tapatalk
  3. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    That was the set. And worked them down more.i have the 430/360cs front calipers now. Just trying to work a deal with someone for the rear calipers. But it will be a full oem big brake up grade with better rotors.
    Stealthssfc and 02360spider like this.
  4. veilstylez
    veilstylez Formula 3
    1,047
    SoCal
    Nice!!! does the master cylinder need to be changed for this?
  5. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    The 430 ccm master is different. Different how I don't know but its a different part #. I will try it first and go from there. And just got the rear caiplers coming.
    armedferret likes this.
  6. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    The CCM vs Steel Master Cylinder is different because it provides additional assistance vs the level you get from the Steel Master Cylinder which is noticeably less assistance so you get better brake progression. Actually I ran with the Steel Master Cylinder for a long time before eventually swapping it over to the CCM version. Some observations. I actually preffered the feeling you get from the reduced level of assistance pressure (i.e the original Steel Master Cylinder). The only reason I kept the CCM version (which is Gold vs Black so easy to spot the difference) is that its a considerable weight saving over the original one. The steel one results in better pedal feel and braking progression but ofcourse you must apply more pressure (not insane amount and totally natural feeling) to haul the car to an emergency stop. Its not a night and day difference but certainly noticeable.
    Stealthssfc likes this.
  7. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    No, its optional but there are differences in pedal pressure and feel. Comes down to personal preference and brake feel and there is a weight saving with the CCM one.
    RANDY6005 likes this.
  8. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    Trev doing iron rotors wounder if thatvwill play a role and the ecu should be there today
  9. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    clean512 likes this.
  10. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    I use exopy for the primer and the color is a single stage urethane. I have done it about 10 times and never ran into a problem. Now if your tracking the car over time anything will discolor. But its all in the prep to.
  11. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    It won't be so noticeable with orange compared to yellow.
  12. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    I think the orange will stick out more than yellow.
  13. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    I was talking about discoloring due to heat if it happens. I do like the orange!
  14. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    Gotcha thanks again
    Flea7 likes this.
  15. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    I'm interested to see how it looks.
  16. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    Your telling me .. waiting for brake lines and rear cailpers will be here this week. On the hunt for the ccm ebrake caipers. But ever source thinks these are gold and charging way to much
  17. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    I know lol
  18. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    I have a new ebrake caliper for the left side....but it's for an F430.....I don't know if it would work. PM me if your interested.
  19. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    Needs to be for the CCM rotor size. Stock 430 is 330mm and 430ccm rotor in the rear is 350mm 20mm difference. Once I get the caiplers I put the rotor on i will like to try and make a spacer or something its only a ebrake
  20. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    It's for a CCB for the 430...yes the rear is 350mm ...part # 196401. Do you need the ebrakes for the normal F430?
  21. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    No need for ccm size donyou have that
  22. Flea7
    Flea7 Formula 3
    1,970
    PNW
    SKIM
    PM'ed you.
  23. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
    Well the parts pile is getting big. Got the rear 360cs/430ccm rear caiplers. Now to clean and re paint
  24. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,135
    Josh @jtcarprojects
