488 - Cleaning 488 Spider top seals | FerrariChat
488 Cleaning 488 Spider top seals
Discussion in '458 Italia/488/F8' started by ferrefeh, Aug 27, 2023.
  1. ferrefeh
    ferrefeh Karting
    184
    Illinois
    Feh H
    Was looking at cleaning some of the rubber seals on the top. Is it OK to open the roof partially to do this, or is there a specific procedure I need to keep in mind...
  2. ferrefeh
    ferrefeh Karting
    184
    Illinois
    Feh H
    Anyone? Can't believe no one has cleaned the rubber seals
  3. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    835
    Michigan
    Tony
    You can open the roof partially and then clean the seals. I do this all the time when I wash my 458 Spider.
    This may be obvious, but I start the car to open and close my roof as it is a large drain on the battery.
  4. ferrefeh
    ferrefeh Karting
    184
    Illinois
    Feh H
    Thanks. I did just that a couple hours ago, and in the manual they do mention that stopping the roof mechanism partially, it's best practice to cycle it to completion. Top cavity was pretty clean and I could see the tube on the hinges.
    Good tip on the engine running while doing the roof operations. Manual doesn't mention this but dealership recommended it this way too.
  5. Mrpseudonym
    Mrpseudonym Formula Junior
    603
    Sydney, Australia
    After cleaning the seals use something like Nextzett gummi pflege as a protectant. Good for door seals too.
    ferrefeh likes this.
