Cleaning aluminium castings | FerrariChat
Discussion in 'Detailing & Showroom' started by Sigmacars, Dec 25, 2018.
  1. Sigmacars
    Sigmacars Formula 3
    1,218
    what is the best cleaner for cleaning the aluminum engine castings top and bottom without affecting the aluminum.
  2. Einsteiger
    Einsteiger Karting
    Oct 9, 2014
    125
    Overland Park, KS US
    Kevin
    I'm not an expert with Ferrari by any means, but Flitz makes a spray product called Aluminum Pre-Clean that might make a good pre-soak before using a brush and a mild engine cleaner like Griot's Garage makes to work off the crud.
  3. staatsof
    95,950
    Fuggetaboutitland
    Bob
    I've done this with the engine out of the car so worrying about affecting other things wasn't an issue. I used aluminum jelly on my engine block a sump pan with a non metallic brushes and water and had very good results but that IS affecting the metal, in a good way.
  4. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    #4 lm2504me, Dec 27, 2018
    The restorer of my webers used WD40, plastic bristle brush to scrub, wipe with paper towels, and repeated the process until fully cleaned. Looks great. I will use electronic cleaner spray to degrease and remove heavy oily stains. The spray works great for cleaning surfaces prior to using RTV or Hylomar for a good sealing surface.
    of2worlds likes this.
