Cleaning challenge rear grill (360) | FerrariChat
Discussion in '360/430' started by scoobyc, May 6, 2009.
  1. scoobyc
    scoobyc Rookie
    Oct 30, 2007
    28
    scotland
    Mine could do with a good clean but i'm worried if i polish it, it will take forever and a day to remove the white polish from the holes. Seen a previous post on here where the owner was using a porter cable (which i have) to buff it up but it didnt mention what polish/cleaner fluid he was using. Any help greatly appreciated, sc.
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    You sure do not want to use polish on it.
    The engine heat will bake the wax and it will look awful!
  3. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    693
    Delray Beach FL
    Russell
    I used to clean mine with Maguires exetrior trim spray
    Works well on the black grills and underside of rear also.
    Russell
  4. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
    I took mine off and had it powdercoated following an attempted cleaning job. If it looks bad, just take if off and get it recoated. If you attempt to polish and wax it, you'll have an absolute mess on your hands, and any results will fade in weeks.
  5. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Very good suggestion.
    I am doing the same.
  6. brokenarrow
    Sep 25, 2006
    3,737
    Txass
    Bill
    It still looks great. I strongly suggest you go with a brighter, shinnier black than is stock because the heat will actually fade it very quickly to what would be stock. And I would say I am there now.
    Cheers~
  7. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Certainly understandable why it's called a "Challenge" grille!
