cleaning crud off eng/trans | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by 2dinos, Dec 7, 2008.
  1. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Read carefully. He mentions his painting step.
  2. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,060
    "Note, I applied a high heat clear from Eastwood and it held up in the hottest of conditions. All it took to clean up the engine after a run in the rain was a light coat of Simple Green to cut the grime and a thorough misting of hot water. The most crucial step was to "blow-dry" after wards with compressed air. If you don't have the compressed air use an electric leaf blower. (Works great for cheese graters too!) "
    Can you use the leaf blower to apply the Eastwood clear coat? :) (sorry) :)
    Do you drive this thing? I stress over my resto's getting dirty, and they're nowhere near that shiny.
  3. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    The Eastwood comes in an aerosol can.
    Before I applied the Eastwood it I "buffed" the aluminum with a rotary wheel (non-metallic) and a drill motor. The rotary wheels I found at the local hardware comes in different coarseness and is used for paint removal from WOOD so you can bet it will not hurt the aluminum. It takes off any left over corrosion and staining.
    I drove the 308 year round in the Pacific Northwest and the engine bay (and chassis) got filthy with the normal "clean" road dirt. A light misting with Simple Green, a 4" nylon paint brush with a thorough mist of hot water got rid of it. Blow dry after.
    As Brian Crall mentioned, don't drive the water into the lower cam bearings.
    I had this 308 for 5 years and sold it a year ago last April. The engine STILL looks like it does in the pictures with just a little less luster..
    Not bad for 7 years of year round driving.
    There is a complete writeup somewhere in Fchat from years ago. I used rubber stopper plugs for the spark plug holes too.
  4. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,060
    Just beautiful! Motor mounts, frame rails etc. Looks great!
    Thanks for posting. Eastwood should use this photo in their ads.
