Cleaning engine compartment | FerrariChat
Discussion in 'Mondial' started by westyguy, Apr 30, 2012.
  1. westyguy
    westyguy Formula Junior
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    I've had my Mondial for about 5 months and have been sorting several items. The engine compartment is FILTHY, though. I intend to pull the engiune next year to replace all the hoses, but I'd like to clean it up a bit now to make it somewhat more presentable. I'm not talking about detailing with a Q-tip or anything nearly that industrious....just a general cleanup. I've considered just spraying it down with Simple Green or similar and then hosing it off after a bit. Thought about the power wash at a car wash also. Any other suggestions?
    Steve
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #2 soucorp, Apr 30, 2012
    Prep and wash outside when car engine is cold. Make sure you cover up all of the electric parts (distrib cap, etc). Simple Green and a good brushing should do the trick. I would not point the nozzle to close to the wrapped electricals either. I would wrap up these parts circled in yellow. But just remember, its going to be the electrical parts that will give you trouble if water gets in there.
    see where Edd starts cleaning the engine at 6mins in the video.
    [ame]http://www.youtube.com/watch?v=xwRl0iqzCwc[/ame]
  3. jgoodman
    jgoodman F1 Rookie
    3,267
    Central PA
    Jay Goodman
    IMHO, do not wet the engine. Water is never friendly to 20 plus year old electrical stuff. You want to paper towel, tooth brush, baby wipe, etc... go ahead, but no water washing. Mike, didn't you just find water pooling in one of the spark plug recesses? Didn't that cause you heartache? I am convinced that moisture killed my ignition coil a few years ago. Water and old electrical connections do not mix.
  4. Valenzo
    Valenzo F1 Veteran
    Dec 4, 2010
    5,069
    IL & NC
    Ted
    +1
    baby wipes, Qtips, small rags soaked with SG and baby bottle brushes.
  5. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #5 soucorp, Apr 30, 2012
    Your probably right, I did not take precautions, should have covered the distrib cap when I washed my wires, I was not thinking straight.
    I think its alot less risky to wipe it down, but its hard to get every nook and cranny without washing and brushing. Done the right way, its doable. Would I do it, prob not with a power washer, but I'll wrap everything up and alittle Simple Green and brush, mist it off with the hose or spray bottle. Thats no more water than being caught in the rain IMO.
  6. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Every time I wash my 308 if I do not cover the engine with a plastic cover and water goes on it I'm 100% sure a plug or two get soaked and need replacing. Now that I know I take care not to do it.
  7. moysiuan
    moysiuan F1 Rookie
    4,191
    Canada
    The electrical connectors are not waterproof, at all. Bad idea to hose these engines down (ask me how I know, actually I would prefer to forget). Definitely not a pressure washer, perhaps dribble from a hose without a nozzle plus simple green or other degreaser would be okay. Might be better to use some loctite degreaser aerosol that evaporates, kind of like brake cleaner for tricky spots, but otherwise use a rag and some detailing sponges on a
    stick soaked in wd40, and with some effort things can clean up pretty nicely.
  8. davidgovett
    davidgovett Karting
    Apr 9, 2010
    134
    I guess I have lucked off. I've had to wash things down after blowing a coolant hose. Hit it all with the garden nozzle taking care not to aim directly at the electrical stuff to get the coolant rinsed off. I'll probably go the route of sealing everything and brushing and hosing off since I have done far worse up till now.
    Dave
  9. rob
    rob F1 Rookie
    May 22, 2002
    4,287
    Vt
    I also would not recommend washing down your engine clean it by hand, I cover my entire engine and also the front trunk area with plastic even when washing just the outside of the car.
  10. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    I wash my car twice a month for the last 8 months without covering engine or front bonnet and never had a problem. I think the caveat is to not to power blast water directly into the open slots but to select a setting on the knob to rain level to rinse the soap suds away.
    Ferrari engineers surely designed these cars to handle rain and if its not a blast of water, I think it can handle it just fine! But do what makes you comfortable!
  11. rob
    rob F1 Rookie
    May 22, 2002
    4,287
    Vt
    I'm heavy handed with the water its just force of habit for me so I'm safer covering things up I just have to remember to take the plastic OFF before I start the engine!
