Cleaning Factory Alloy Wheels
Discussion in 'Detailing & Showroom' started by ShadowLAP, Nov 17, 2017.
  1. ShadowLAP
    ShadowLAP Rookie
    37
    Illinois
    Larry
    Before I use any cleaning products on my 360 Spider Alloy wheels I thought I would check for advice from the members as to the best products to use. thansks and appreciated for any advice. Image Unavailable, Please Login
  2. tmvatlanta
    tmvatlanta Karting
    Mar 26, 2017
    57
    Lilburn, GA
    Tam V.
    Any car soap should be fine. It's just a paint surface with clear coat like a body panel.
    whatheheck likes this.
  3. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    5,801
    Wash DC area
    Robert
    Ditto
  4. Echo Charlie 1131949ZULU
    Sep 11, 2017
    6
    Edward C. Chewning
    Do you take your wheels/ tires off the car to clean them.? Edward
  5. LBBP
    LBBP Formula Junior
    Dec 8, 2014
    291
    Concord, TN
    docf likes this.
  6. ShadowLAP
    ShadowLAP Rookie
    37
    Illinois
    Larry
    I just purchased the car on Monday and have driven it once. More than likely I will not take them off on a regular basis. Maybe once or twice per year to do a proper cleaning.
  7. Tired of seeing this ad? Upgrade now
  8. Jsf721
    Jsf721 Karting
    May 15, 2015
    93
    If you have carbon fiber brakes do not you anything other than car wash soap.
  9. killer58
    killer58 Formula Junior
    447
    I use Simple Green and a soft kitchen bottle brush.
    After 7 years, they still look new.
  10. Admiral Goodwrench
    Admiral Goodwrench Formula Junior
    Mar 2, 2005
    264
    Santa Fe, New Mexico
    Robert Phillips
    Dear David,
    A dozen or more years ago the Army banned the use of Simple Green on their helos. About the same time NAVAIR banned Simple Green from being used on any aircraft after some problems on the Hornets. As I understand it the company reformulated the product and is now considered safe to use if it is Extreme Simple Green Aviation. Apparently the original product caused hydrogen embrittlement on steel and was destructive on aluminum. Hope you are using the right stuff.
    Best regards,
    Robert
  11. docf
    docf Formula Junior
    Sep 14, 2008
    760
    Florida
    Gary
    Sonax wheel Cleaner- Ph neutral, Acid Free. Intend to use it on my 458 with carbon breaks. Now new Sonax plus is out. Contact Auto Geeks or Chem guys if you have selected Issues regarding safety of this product with your wheels/brakes. Can now also by this product on Amazon.
  12. eyeman1234
    eyeman1234 Formula Junior
    Silver Subscribed Owner
    Dec 25, 2006
    649
    Palm Beach County FL
    And a Boar's hair brush (for the purists!)
  13. msark
    msark Rookie
    41
    Southern California
    Just looked on Amazon for the Sonax ... There is a wheel cleaner, wheel cleaner plus and wheel cleaner full effect .... Which is the one you are using now with success?
  14. Tired of seeing this ad? Upgrade now
  15. Solid State
    Solid State Formula 3
    Rossa Subscribed Owner
    Feb 4, 2014
    1,741
    Can confirm Simple Green will react with bare aluminum. The rims are clear coated but there's lots of bare aluminum in the wheel area. If it sits long enough it will harm the raw aluminum finish on parts. Regular car wash for the wheels but you'll have to remove them eventually to get them new again. The wheel hangers sold on this site will make a good stocking stuffer.
  16. LBBP
    LBBP Formula Junior
    Dec 8, 2014
    291
    Concord, TN
    The Full Effect is the one to use, all three work, but the F.E. is faster acting and does the best job on the oily grime/brake dust. All the while the product is safe on all wheels, don't rinse your wheel prior to applying F.E. to achieve the best results.
    Use a Wheel Woolie and a lug brush to lightly agitate, rinse and admire your clean wheels.
  17. obbob
    obbob Karting
    Aug 14, 2017
    130
    Do not use wheel cleaners on carbon ceramic rotors! At worst, they can damage the surface of the delicate rotors by being too harsh. At best, your rotors will squeak alot more than before.
    Carbon Ceramics produce very little brake dust anyways - wheel soap or even car soap is more than enough to clean everything.
    timjen88 and docf like this.
  18. peterp
    peterp F1 Rookie
    4,992
    NJ
    Peter
    #16 peterp, Dec 5, 2017
  19. Makuono
    Makuono Formula Junior
    391
    Ricardo
    Beautiful 360. Those rims are gorgeous.
  20. YorkieV12
    YorkieV12 Karting
    May 23, 2014
    84
    Liquid soap and plenty of warm water.....regularly.
    A customer of mine, sprayed alloy wheel cleaner onto his front screen thinking it would clean off traffic film.
    Phone rings...goes to answer...makes coffee..etc etc goes back to car 15 mins later...........needs new screen.
    If you wouldn't wash your face with it.....why spray it onto your wheels.....a corrosive substance isn't selective...Ford/Fiat or Ferrari ! makes no difference
    peterp likes this.
  21. peterp
    peterp F1 Rookie
    4,992
    NJ
    Peter
    Agree with the above, for cars that are are babied and washed regularly, you never need anything more than car wash soap. For a DD that has brake dust sitting for a while, that's when you need chemicals.
    A lot of people treat wheels with "Rejex" polish, which really helps repel brake dust as long as you let Rejex cure fully (12-24 hours) before driving. Any car polish will help reject brake dust a bit, but Rejex is better than most. Rejex used to be considered by many to be the "best" product for brake dust rejection, but Rejex has been out for a long time at this point, so I don't know if there is something better now.
  22. timjen88
    timjen88 Rookie
    Aug 20, 2015
    31
    Colorado, USA
    Wish I read this one before I used a cleaner. Never had squeaks on my FF, but now I do :(
