cleaning inside crank sensor F355 ?? | FerrariChat
Discussion in 'Technical Q&A' started by fana355france, May 14, 2007.
  1. fana355france
    fana355france Formula Junior
    284
    France
    nicolas
    I red on this forum that it was possible to clean inside the crank sensor (MAS)
    because it could cause ignitions troubles.I still have my cutting out cylinders problems so today I decide to remove the crank sensors to clean it.
    I dont understand how to clean the inside because it seam to be one part made, not possible to seperate any part of the sensor ??
    any explaination ?
    thanks
    nico
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Are you sure your talking about the crank sensor and not the Mass Air Flow Sensor (MAFS)???? The crank sensors are on the bottom front of the engine. The MAFS is located on the top of the engine just after the air boxes, or between them depending on the year of your 355. If it's the MAFS you are talking about you can use electrical contact cleaner. It usually comes in a spray can.
  3. fana355france
    284
    France
    nicolas
    maybe I did not understood well....but what you say interess me too because I did not clean the inside of MAFS...maybe it can help...I have a 2.7 so I have 2 MAFS that is true ?
    Thanks ernie
  4. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    The 'crank trigger sensors' are a magnetic type I believe, so dirt should not affect them..... :)
  5. fana355france
    284
    France
    nicolas
    I had such a problem on my 348, oil was coming on and cleaning it, solve my ignitions troubles.But not on my 355 ! realy sorry of it !!
  6. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Yes, you have two of them. Be sure to also clean the connectors for the MAFS.
