Cleaning Red head covers any ideas | FerrariChat
Discussion in 'Detailing & Showroom' started by buckleup1, Mar 21, 2015.
  1. buckleup1
    buckleup1 Rookie
    Mar 21, 2015
    1
    Newbie here....Never tackled cleaning red engine covers. I understand you can use degreaser or brake cleaner just want to know the best results out there. Trying to avoid hosing the whole engine. I have a 430.
  2. SizzleChest
    SizzleChest Formula Junior
    Dec 15, 2014
    255
    Naples, FL
    Scott
    You can use an all purpose cleaner (APC) and a few brushes to clean the valve covers. Try diluting the APC with some water first and do a 'test spot', a small area of your cover to see if it is giving you the results that you want...it will also make sure that the APC/cleaner is not 'too strong' and will not stain/etch/etc your aluminum covers.
    I have used some old soft tooth brushes in the past with good results to get into the small areas that you will need to get into.
    After cleaning, I would then spray the covers with some water or a detail spray/waterless wash or the like to rid them of any left over APC/cleaner.
    Hope this helps some!
    Let us know how you make out!
  3. Deiger
    Deiger Formula Junior
    Jul 4, 2011
    453
    I will second the above post. I have had good luck with Simple Green diluted. Let sit for a few minutes and then use a light spray of water to rinse. Dry with a towel. Then after about an hour of residual drying I add a little CD2 engine detailer. Let that sit for a couple of hours, wipe off residual with a soft towel. This should keep them looking good for many weeks to come.
    Final step, go get your neighbor to admire all your hard work.
    Post pictures of your results, always love to see great engine bays.
    Deiger
  4. Jean-Claude
    Jean-Claude Karting
    Sep 23, 2009
    187
    Atlanta
    p21s Total Auto Wash is the single best citrus automotive cleaner I know of.
  5. LIDetailers
    LIDetailers Rookie
    7
    Long Island
    Andrew
    Use an APC or Citrus Degreaser and agitate with a brush. Rinse, dry and you're done. If its really stubborn you may want to use a steamer to clean it safely rather than use harsh chemicals that could damage something.
  6. Jsf721
    Jsf721 Karting
    May 15, 2015
    93
    I have never heard of armor fusion. It that a private bran coating of yours?
  7. synergy
    synergy Formula Junior
    Aug 5, 2007
    522
    Austin Texas
    Chris
    I have been using Zep green spray degreaser and it is keeping my red engine covers super clean.
  8. Esoteric Auto Detail
    Esoteric Auto Detail Formula Junior
    Dec 14, 2008
    822
    Columbus, OH
    We have cleaned a lot of 430 engines...a LOT of them. We have never had to use anything stronger than standard shampoo, a light brush, and a rinse of water to fully clean them.
    If yours is rough and requires something stronger, then use a diluted APC on a cold engine, lightly agitate, and immediately rinse.
    You can use something like this if you need to (good to have this around anyways). Sonax Multistar APC | Esoteric Car Care
    Let us know if you have any additional questions.
