Cleaning the Engine | FerrariChat
Cleaning the Engine
Discussion in 'Detailing & Showroom' started by PhilNotHill, May 9, 2015.
  1. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    #1 PhilNotHill, May 9, 2015
    Used Search but could not find anything... Engine cleaning.
    Am afraid to turn a hose on the engine. So i use engine cleaner with a spray can/bottle and remove with Windex and water (spray bottles). To reach nooks and crannies i use a barrel cleaner for a 12 guage shotgun which 3-4 feet long and about an inch in diameter. The wool or synthetic fabric has to be washed in hot soapy water to get the dirt out.
    Anybody have some methods that you would like to recommend?
    BTW my 458 Spider engine seems to get dirtier than my old F355 and 360.
  2. ModenaInv
    ModenaInv Karting
    156
    South West Michigan
    Dave
    I have the same question for my 308. What cleaner is best for raw metal parts in the engine compartment such as valve covers. Blasting the engine with a hose makes me a bit nervous. Any suggestions?
  3. SizzleChest
    SizzleChest Formula Junior
    Dec 15, 2014
    255
    Naples, FL
    Scott
    I have a steamer I use. It works great! I also use some All Purpose Cleaner (APC) and some microfiber as well as some small brushes to get into the nooks and crannies that aren't easily accessible.
    I clean with the APC and brushes, and then hit it with the steamer to remove any residue/additional dirt/etc that needs to be removed.
    Cleans up great!
    If a steamer is not an option, then you can use any variety of waterless wash or APC for heavier areas and then 'rinse' with a spray bottle of distilled water so you lessen the chances of leaving water spots.
    Finish with your choice of dressing/coating/etc and you are finished!
    Hope this helps you!
  4. shross
    shross Karting
    Sep 11, 2005
    162
    Calgary, Alberta
    #4 shross, May 11, 2015
  5. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    The last time I cleaned my engine, I used Scrubbing Bubbles and it left a white haze film over everything after being rinsed off - just not for me. Next time, I am just going to use "Purple Stuff" degreaser.
    The Griots engine shine was REALLY good.
  6. kalinsd
    kalinsd Formula Junior
    Apr 14, 2010
    438
    Washington
    DJ
    This fellow does lots of detailing. Go to the Detail page and then look for "Engine Detail". He does some very nice work.
    Detailing - Rick's Audi Double
    DJ
  7. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,187
    NYC. / E. Hampton
    Michael
    #7 msdesignltd, May 11, 2015
  8. SizzleChest
    Dec 15, 2014
    255
    Naples, FL
    Scott
    I would stay away from any non automotive use product such as bathroom/household cleaners. These can tend to be very harsh/acidic and can possible do more harm than good.
    ncjetskier seems to have had such an experience. I would say that the harsh chemicals in this cleaner, while being allowed to dwell, caused the discoloration to your engine bits/pieces.
    Just my opinion is all...
  9. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    Any recommendations which brand of steamer to buy, or best place to find one?
  10. SizzleChest
    Dec 15, 2014
    255
    Naples, FL
    Scott
    Dupray is one of the top notch brands. I am using a Mcculloch right now. Amazon or one of the online detailing stores carry them.
    Looks at some of the reviews and that will help you decide what YOU need for what you will be using it for. You can spend some $$$ on them, that's for sure!
  11. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    I used engine cleaner the first go around and then Simple Green. I found the Simple Green worked best. I made sure to rinse off the block VERY well with water after using the Simple Green.
  12. regferrari
    regferrari Rookie
    Apr 14, 2013
    25
    I use the water hose and my regular car wash soap, with a pure bristle round paint brush for the small corners.
    I did this with my 360 and I do the same with my 458
    no problem at all
    those engine are made to be used in the rain too
    if you use some water to rinse of your car, the water gets on your engine anyway....
  13. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I've been very impressed with the Griot's engine cleaner. Seems to remove as much grease/grime as more aggressive products, but it won't harm alloy like some other products. I love Simple Green, but don't use it on the engine as a whole because the detailing gurus warn it can discolor some alloys.
    The main concern in hosing down an engine is to make certain to cover sensitive areas/components with foil and/or plastic bags, tape, etc. That's kind of a pain to do in a mid-engine car, but still easier for me than scrubbing small areas. Blow drying with a leaf blower helps as well.
  14. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    This is most helpful.
  15. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    Ditto on the simple green. Then the next day after engine is completly dry, I warm the engine and spray Armorol on it, the next day wipe off excess with a cotton cloth. Looks showroom fresh
  16. blown daytona
    Feb 6, 2008
    1,679
    maryland
    I like the leaf blower idea (I have been using shop air) I am going to try that
  17. SierraBravo
    SierraBravo Karting
    Jul 13, 2014
    164
    Montana
    Steve
    I'm no expert but I agree with this approach and have had no problems. Is there anything less caustic than good ol' H2O and if car wash soap won't hurt your paint and metal trim, it shouldn't hurt anything under the hood. Add a little brushing with a small soft brush, a terry rag or two and finish with a rinse and leaf blower and viola.
    No experience with Griot's but FWIW, I'd stay away from anything that says "bathroom" on it.
  18. Jsf721
    Jsf721 Karting
    May 15, 2015
    93
    Polish angel makes a spray on wipe of product called engine that cleans and protects.
  19. Ski Bum
    Ski Bum Formula 3
    Jun 19, 2012
    1,088
    I use a diluted APC (Grime Reaper) and a spray bottle of deionized water to rinse. I scrub where necessary using a soft detailing tool made for wheels (NO wire or metal). I dry with a microfiber wipe or towel.
    The most important thing with a mid-engine car -- make sure that you are not wearing any metal on your pants or shirt, or you will end up scratching the exterior finish (even if you lean on a towel).
  20. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Ernie, I would be careful with Simple Green. Make sure you use the one specifically for Aluminum, the regular Simple Green is great on Steel (acidic) but not good on Aluminum (need a base).
  21. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Can you show which areas you tape off in pics for a 430 and 458? Thanks :)
  22. geochin
    geochin Formula Junior
    Jul 3, 2012
    306
    NJ
    George
    Hi Felipe
    I don't think it's a problem hosing down the engine, provided you cover the the fenders, etc to prevent splashing dirt onto the paint and have car running. I have a 458 spider and it is much harder than my 458 coupe since I can't get to the front of the engine of the spider unless you take apart the roof section. However, my spider engine compartments looks brand new after 13k miles. To prevent any dirt , I cover the engine with a towel before I wash the car so a minimal amount of water gets into compartment thru the 2 vents.i then use a air hose to blow out any residual water. Dirt tends to build up in the crevices on the valve covers where water tends to settle. b careful with shotgun cleaner lol
  23. Jsf721
    Jsf721 Karting
    May 15, 2015
    93
    Posted it once and I'll say it again. Polish angel engine. No hose and it leaves protection behind.
  24. tonyswfla
    tonyswfla Formula Junior
    823
    Florida
  25. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Sorry-- I have a 348, so I can't help specifically. But I try to protect any openings such as air intakes, and even the oil filler cap on some cars (I don't think that's an issue on Ferraris though). Wiring connectors and especially the alternator need to be covered. Better to be safe than to risk damaging an expensive part.
    BTW, Aerospace 303 protectant is awesome stuff to use on painted and plastic surfaces after the engine is clean and dry. It drys to the touch, so it doesn't attract dust, and it has UV protectants to help keep exposed colors from fading. I recently used some in the cowl area under the wipers on my 348 and it now looks brand new. Great stuff for lots of different uses.
    Best of luck cleaning your engines. Wish I could be of more help.
