360 - Cleaning under engine bay side covers | FerrariChat
360 Cleaning under engine bay side covers
Discussion in '360/430' started by Scottrx7tt, Feb 10, 2024.
  1. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    230
    Lenoir City, TN
    Scott Williams
    So, I’ve seen where everyone recommends scrubbing bubbles to clean the engine bay, etc. but have not seen any recommendations on cleaning under the side covers? Any recommendations for that? Is it still safe to clean with scrubbing bubbles and rinse with water since the ECUs are underneath there?
  2. anotherred360
    anotherred360 Formula Junior
    Jan 10, 2015
    278
    You could unbolt the ECUs from their brackets and spot clean with a toothbrush or similar then put a plastic bag over them. Pretty simple to do but 1 or 2 of the nuts are tucked up in there. When I pulled mine to be tuned there was a lot of oily build-up on the surface/heatsink, so I would definitely clean them while you're in there and not simply cover up and clean everything else.
  3. andrejwolk1975
    andrejwolk1975 Karting
    Feb 28, 2020
    118
    Italy
    Andrea M
    Compressed air, a soft brush, a microfiber towel, elbow grease.... That's all.
    Detaching, unscrewing, unfixing.....better not.
    Old parts, old.connectors, old brittle cables, old screws, old ties..... "The one who searches for troubles....at the end finds them..." My two cents
    ItalGerBrit and Bob in Makiki like this.
  4. 67bmer
    67bmer F1 Rookie
    2,979
    MD
    For greasy/oily things I use paint thinner with a paint brush and then wash off with a hose.
    Then I use LA Totally Awesome diluted 50/50 (from Ollie's) with a cheap paint brush cleaning every surface, nook and cranny and then hose off.
    For the paint brushes, I get the Home Depot wooden handle ones for like $.85 or what ever they are. Typically 1 inch wide.
    When done, I fire it up and let it get warm and evaporate the water off the engine.
  5. RedNeck
    RedNeck F1 World Champ
    12,334
    The CSA
    Me
    Just put the cover back on ;)
    colorfull, Oengus, Plainview and 4 others like this.
  6. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    I wouldn’t go spraying water or cleaner, especially Scrubbing Bubbles on all that wiring and connectors.
    My engine is spotless, but under my side covers it’s filthy too. I just left it dirty and out the covers back on.
    bernieb likes this.
  7. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    This whole scrubbing bubble is a joke. Keep those products away from my car. Use real detailer products with the right chemicals. Stick with a mild APC and good brushes. Light flow of water or steam.
    That is all you need.
    RANDY6005 and Edward 96GTS like this.
  8. AandSC
    AandSC Formula Junior
    958
    Jax, FL
    Allen
    I’m guessing they figured out somewhere along the way that they should move those electrical components. My 08 is pretty minimalist under the covers. And easy to clean.
    colorfull likes this.
  9. andrejwolk1975
    Feb 28, 2020
    118
    Italy
    Andrea M
    Ferrari sometimes seems to forget how to do something the best way. For example, ECU location: 355 cabin, 360 engine bay (hot!!), F430 again in cabin. Exhaust more "dampened" in 360, in F430.... no and more vibrations (and more likely to have broken headers...).
  10. Niklasbraun
    Niklasbraun Karting
    Nov 30, 2023
    54
    Nuremberg
    Niklas Braun
    If you've got a can of compressed air lying around, it's a pretty neat trick for getting rid of dust and junk from tricky spots without needing any fancy cleaners or water. Plus, if your vacuum has one of those brush attachments, you can give it a gentle go to suck up the dirt and grime hiding under those side covers.
  11. eric355
    eric355 Formula 3
    1,227
    Toulouse (France)
    Eric DECOUX
    458 again in engine bay ...
