Cleaning Valve Cover-Head Mating Surfaces | FerrariChat
Discussion in '308/328' started by mwr4440, May 13, 2012.
  1. mwr4440
    57,968
    Bavaria, The 'Other' Germany
    Mark W.R.
    Ok.
    Need the brain power and experience of all you geniuses here as I am a Class-A dummy, :D
    How the heck do I clean the mating surfaces between the valve-covers and heads "spick and span" for the new gaskets & seals to be inserted? These surfaces are D-I-R-T-Y.
    Obviously I want to minimize the amount of crud that comes loose from getting into the engine.
    What is the BEST products and tools and procedures to use?
    What are the things NOT to do?
    BTW - Motor is IN.
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    #2 MNExotics, May 13, 2012
    Penetrant oil a razor and patience. Sometimes that not enough especially if you had the crappy black gaskets tha superformance sells (not putting superformance down just the gasket they sell). If that is the case spray the head w/brake cleaner and cover the cams and valley with a rag and seal with duct tape. You will need scotch bright pads at that point. They do make a scotch bright attachment for dreml and drills but keep the pads wet with oil. After you do that job once you will appreciate the value of the green gaskets.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Careful use of a single-edge razor blade, followed by a small piece of scotchbrite with carb-cleaner to get everything squeaky clean. An assortment of picks and small scrapers at your disposal for the tricky spots can be handy.
  4. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    I know this sound a little weird but using a little cooking spray on the new gaskets ensue they come off easier next time you do the job.
  5. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    Its obvious, but be VERY careful about crud dropping where it may get into the oil passages.
  6. phrogs
    phrogs F1 Veteran
    7,345
    Kzoo Michigan
    vacuum cleaner/shop vac whatever you used hold the hose next to where your scraping with the Razor blade to suck it up as you scrape.
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    All of the black gaskets sold by a few folks here in the States can cause these same problems. Cheaper upfront, a royal pain down the road...
    Power tools of any sort and aluminum do not go hand in hand. In extreme cases, just pull the studs and spend the time.
    So true!
  8. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    #8 Constance, May 14, 2012
  9. George Vosburgh
    George Vosburgh F1 Rookie
    Constance,
    What did you use on your belt covers? They look great!
  10. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    #10 Constance, May 14, 2012
  11. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    #11 Constance, May 14, 2012
  12. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Bah
    I have seen people scratch surfaces with razors and picks.
    Like anything if you take your time you will be fine with a power tool
  13. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    Using an appropriate scraper tool will prevent scratches and nicks,
  14. mwr4440
    57,968
    Mark W.R.
    Thanx All,
    Looks like I just got a long row to hoe ............. :(
    Oh well, there are "happy moments" and "not so happy moments ......"
    To borrow a phrase ..... "FORWARD!!!"
  15. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    #15 fastradio, May 15, 2012
    Nah...
    Aluminum is much softer than you think. Here's are two perfect examples why power tools should never be used on aluminum.
  16. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    #16 Saabguy, May 15, 2012
    hmm... are you sure that you would call that the fault of the power tool and not the user in choosing too abrasive a material? I too have seen folks cut out pieces of aluminum using a single edge razor, the angle gets off just a bit and off come aluminum bits. I would think that the proper abrasive disc would work a treat although a bit messy.
    Lester
  17. mwr4440
    57,968
    Mark W.R.
    David,
    Well ....... it IS CLEAN ................ :eek:
    Kill-Joy.
    Serious Question: Will the "Green" gaskets (likely) prevent those cratches in the pics from leaking?
  18. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    #18 MNExotics, May 15, 2012
    Bah I say
    Bah
    Cleaned no gouges and as you can see the black gaskets were used. You can screw things up using either method and some people are out of their skill set using tools where surface finish is important. In the end you should use any tool only if you know what you are doing and power tools can be used but the black gaskets should never be.
