Cleaning yellow rad fan blades? Help please | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by ONSilver, Aug 5, 2018.
  1. ONSilver
    ONSilver Karting
    May 26, 2008
    183
    Oakville, Ontario
    What could I use to clean the yellow plastic fan blades behind the rad on my 412? They look discolored and horrible! Thanks!
  2. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,189
    CA & DC
    I used simple green and a plastic bristle brush.
    All most the stubborn stuff came off
    It didn’t look brand new, but damn close.
  3. ONSilver
    ONSilver Karting
    May 26, 2008
    183
    Oakville, Ontario
    Thank you! I'll try that, with before and after pictures to come!
  4. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,189
    CA & DC
    Make sure you let the Simple Green soak for a while.
    And don’t use anything that will will scratch the plastic fan else it will ultimately look worse
  5. ONSilver
    ONSilver Karting
    May 26, 2008
    183
    Oakville, Ontario
    Great points, thank you. I assume after the brush work I'd rinse off with clean water?
  6. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,189
    CA & DC
    Yes, just rinse with water.
  7. ONSilver
    ONSilver Karting
    May 26, 2008
    183
    Oakville, Ontario
    Thank you once again!
  8. Cdcasarella
    Cdcasarella Rookie
    Apr 29, 2016
    20
    pound ridge ,ny
    charles casarella
    Hi Oliver, Charles here from NY, will you be coming to Watkins Glen FCA meet ? Hope to see you there,
    I am bringing my 412 also.
    regards
    Charles
  9. ONSilver
    ONSilver Karting
    May 26, 2008
    183
    Oakville, Ontario
    Hi Charles, yes am coming! Look forward to meeting up with you! Drive carefully and see you there! Best, Oliver
