Clear and slippery fluid leaking... | FerrariChat
Discussion in '348/355' started by 44qsake, Apr 15, 2018.
  1. 44qsake
    44qsake Rookie
    Oct 25, 2011
    36
    ...from the engine, passenger side, after sitting for the winter then starting the engine. When touched, the fluid looks like water but feels like oil. I had thought perhaps brake fluid, but there's a good too many years on what's there, about 6,000 miles since it was last changed.
    Any ideas what and why?
    1996 F355 Spyder with manual gearbox.
  2. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Have you checked your shock absorber?
  3. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    783
    Treasure Coast Florida
    MATT
    Scoop up enough and see if it is soluble in water if so then it's brake fluid if not probably shock absorber fluid.
  4. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    Did you try to trace where its comming from?
    It will lead you back to the leak.
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    did you find it before or after starting the engine? If after start, could be just water/condensation from a spot where there is an exhaust leak.
  6. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    AC refrigerant oil possibly (don't ask me how i know)?
