Clear front lens | FerrariChat
Clear front lens
Discussion in '348/355' started by hammer1, Oct 29, 2010.
  1. hammer1
    hammer1 Karting
    Oct 5, 2010
    121
    Louisville, KY
    Chris Morris
    Hello all,
    Can someone direct me to a place I can order the Euro "clear" front turn/parking lens?
    Chris
    97 - 355
  2. f355spider
    f355spider F1 World Champ
    18,052
    #2 f355spider, Oct 29, 2010
  3. hammer1
    hammer1 Karting
    Oct 5, 2010
    121
    Louisville, KY
    Chris Morris
    Thank you very much, guess I could have done that! Oops, thanks again.
    Now wonder were the side markers are in clear?????? hint hint:);)
  4. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #4 sambomydog, Oct 29, 2010
  5. hammer1
    hammer1 Karting
    Oct 5, 2010
    121
    Louisville, KY
    Chris Morris
    Thank you do you have a picture of your fcar? thanks
    Chris
    QUOTE=sambomydog;140017244]Here in the UK we have clear front light lenses as standard. www.eurospares.co.uk sell them also.
    I personally also use clear side wing indicators which look great;) http://cgi.ebay.co.uk/FERRARI-348-355-360-F430-550-599-Clear-Side-Lights-Lens-/110597292481?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19c01cc1c1
    Regarding the US style side markers, thank god UK cars dont have them. They look to fussy with a hint of afterthought IMO.[/QUOTE]
  6. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Hammer1, i have sent you a PM.
  7. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Chris:
    I have the clear front lamps on my F355 and I also wanted to replace the front (and possibly the rear) side marker lamps with a clear lamp assembly. As you may know, they are a one-piece assembly and there is no (simple) way of removing the lens without using a fine blade saw, I did a pretty comprehensive search to find a similar sized unit that used a similar mounting arrangement (I didn't care about the wiring as I could always re-wire). Unfortunately, no joy. :( Perhaps someone (Daniel) might be able to help with this issue. I think most people with clear front lamps would also opt for clear front marker lamps.
  8. hammer1
    hammer1 Karting
    Oct 5, 2010
    121
    Louisville, KY
    Chris Morris
    saw,
    Thanks for the feedback. Where did you purchase your front clear lens? I was also looking to replace the side yellow markers and was going to check them tonight, i didnt know they were all one unit? Where are they available in clear??????
    Are you using standard colored bulbs up front behind the clear or LED"S
    Chris
    Any pictures????
  9. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    RICAMBI. There is no substitute......
    I am using incandescent bulbs in the front but I switched to LEDs in the rear, thanks to f355spider's great research and information.
    The Amber side markers are a one-piece unit. These are the ones I wanted to replace, but I couldn't find a clear lens unit that would work.
  10. hammer1
    hammer1 Karting
    Oct 5, 2010
    121
    Louisville, KY
    Chris Morris
    If you replaced the rears with LEDs did you get any fast flash on the turns or did you use a regulator inline?
  11. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    I too would be very interested in clear side markers for the front and rear bumpers. Let me know if you have any luck.
  12. hammer1
    hammer1 Karting
    Oct 5, 2010
    121
    Louisville, KY
    Chris Morris
    OK 355 spider I have searched the forum before asking but can you share the rear LED data that was discussed above i could not find it in my search.
    Chris
  13. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
  14. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I have all LED's front and rear. The flashing rate went way up (faster). I would say it's too fast. You have to add load resistors to get the flash rate back to normal. Unfortunately those load resistors can get pretty darn hot and you lose one of the advantages you just gained (reduced electrical load on the alternator or battery, as the case may be).
    An alternative would be a flasher unit that is electronically timed (not load dependent) but that may be problematic as the 355 flasher isn't as simple as on some cars.
  15. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #15 eulk328, Oct 29, 2010
    The only reasonable and realistic option is to get your car painted black and then get the ugly side markers "smoked." :)
  16. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Wow, now that's what you call "blending in". Looks great.
  17. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    best looking american spec 355 ever
  18. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #18 eulk328, Oct 29, 2010
    Thanks (although the previous owner had it done). I removed the standard bulbs and put in 1 watt amber/red LED's (front/rear). They're bright enough to cut through the smoked lenses although the beam of light is more of a spot than the "spread" of the incandescent bulbs. Still.... does the job fine.
    Even in the bright midday sunlight of the Mojave Desert the little 1 watt LED can be seen.
  19. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Thank goodness they standardized the mirrors for U.S./non-U.S. on the 348/355 so we don't have to suffer the U.S. spec. 328 atrocity. :)
  20. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #20 eulk328, Oct 29, 2010
    I "un-oranged" my Euro 328 a few years ago. Orange and red just don't compliment each other...
  21. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    The side marker lamps in clear or white are illegal in many parts. There is a reason why red and orange markers are used on cars.
  22. hammer1
    hammer1 Karting
    Oct 5, 2010
    121
    Louisville, KY
    Chris Morris
    Thanks and YES I understand that, thanks for pointing that out!! Does not stop me from asking the question or wanting the result!!!!! Thanks anyway!
  23. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    The last time I was talking to Oz (Gothspeed) he mentioned he might do a run of clear side markers. Hit him up and see if his project is still a go.
  24. Ryan Pafford
    Ryan Pafford Rookie
    Oct 30, 2019
    13
    DFW
    Ryan Pafford
    Reviving a 10 year old thread to say, I had some clear side markers made for my Rosso Corsa F355 because the orange bothered me that much.
  25. OCKlasse
    OCKlasse Formula Junior
    709
    Newport Beach, CA
    Brandon K
    Looks great!
    Ryan Pafford likes this.
