355 - Clear turn signal refurbishment project | FerrariChat
355 Clear turn signal refurbishment project
Discussion in '348/355' started by Culprit, Jun 10, 2020.
  1. Culprit
    Culprit Formula Junior
    509
    Santa Ana, CA
    Ian
    Hi all!
    I’m excited to share with you a hobby project which has gotten a bit out of hand..
    In the past few years, F355 turn signal units have started to become very rare, and especially the European-style clear units are hard to find and are now selling for 4 figures per set. The clear units are certainly favorable to the orange ones, and switching them out is one of the nicest and simplest upgrades for the F355.
    I started to research the possibility of replicating or refurbishing these parts. I bought some spares and cut them open... These are not designed to come apart easily!! They are actually made of three parts which are fused together - the housing, the outer lens - and a clear inner lens.
    The initial plan was to 3D print the outer lenses, but quickly it became obvious that the qualities we want in the lens - clarity, UV resistance and shatter resistance - were not well suited to 3D printing. Actually, I found that these parts take very well to being resin cast. By casting these, we can achieve crystal clear parts which closely emulate the properties of the injection molded originals.
    So I started researching resin casting, and buying equipment to start creating prototypes. This was a completely new process to me, and I enjoyed learning about different silicons, resins, clays for creating molds, heating techniques, vacuum degassing, curing etc. The projects was especially though since we’re dealing with clear parts - any imperfections cannot be fixed with bondo!
    So anyway, after many, many months of research and trial & error, I was finally able to achieve the results I was looking for!
    I’ve created 3 additional sets to partly offset the investment I have into the project. They will be listed in the for sale section.
    Please share feedback on the project! It has been a great hobby so far, and a good excuse to buy more cool gear for the garage. If there is significant interest, I’ll consider pursuing this more earnestly and manufacture additional units, or cast other NLA parts the community might be looking for. Currently there are more man hours involved in each part than I care to admit, and to scale up production, I need to invest in a compression chamber, compressor and a few other materials & tools.
    tres55, bcar1, bjwhite and 6 others like this.
  2. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,028
    NE FL
    Ken
    Wow, very nice
  3. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    Beautifully done!!! Wow!
    Culprit likes this.
  4. ruey220
    ruey220 Formula Junior
    316
    Sf bay area
    RM
    Awesome this looks really well designed.
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    348 fog lights are similarly scarce and pricey and I would think be a high demand for. I know I need a pair.
  6. WATSON
    23,922
    WI
    Wowza. That's impressive.
  7. Culprit
    509
    Santa Ana, CA
    Ian
    Thanks for the kind comments!
  8. Culprit
    509
    Santa Ana, CA
    Ian
    I’d love to help out the 348 guys as well. The fog light lens is made of glass on the 348? At least it looks like just the outer lens is designed to be replaced more easily? This might be a lot simpler than the F355 project. If I cast those as a lightweight, more economical alternative, you think there’d be some demand out there?
  9. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I think one can just buy the 348 lens which isn't that $ but the whole fog light assembly is $2K+ and up for decent usable ones.
  10. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Well done and impressive. See how these three sets move decide if it’s worth the effort. Good luck!
  11. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Fog light lenses, the Carillo ones? They are easy to find I have 2 new sets in the box.
    For example http://www.superformance.co.uk/348/lights.html
    The 355 casting looks great, what was the material used?
  12. ShineKen
    ShineKen Two Time F1 World Champ
    20,036
    Southern California
    Nostradamus
    This is awesome!
  13. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,808
    Seattle, WA
    Brian White
    Fantastic job Culprit! Almost makes me wish I had a 355. Almost.
  14. Culprit
    509
    Santa Ana, CA
    Ian
    I use a 2-part polyurethane system from a local company called BJB (WC-783). The resin takes a good while to fully cure, but the quality of the final product is great. The material is crystal clear and is resistant to impact, oxidation and UV light.
  15. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    Are they a replica of the originals? I'm from Down Under. When and if you need RWC all lights, indicators and such must comply with ADR. Do your smick lense have the ADR compliant applicable No's on them. Reason I ask is they look great. Well done
  16. Culprit
    509
    Santa Ana, CA
    Ian
    That sounds like a strict inspection process! The lenses have international E markings and indicate SAE standards and DOT compliance. Could you confirm if this matches what you require in Australia?
    Qavion likes this.
  17. Beetle
    Apr 10, 2013
    776
    DOT and SAE perfect well done. Due to so many after market products RWC inspectors are pretty tough on the ADR compliance.
  18. texasnoiz
    texasnoiz Rookie
    Oct 7, 2018
    35
    Sugar Land
    k s
    you got skills. bravo!
  19. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Very nicely done, Ian!
    Barry
  20. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,277
    CT
    John Kreskovsky
    Does the index of refraction match that of the OEM lens material? (Had to ask. ) :)
  21. gf1red
    gf1red Formula Junior
    Mar 5, 2006
    413
    Staten Island N.Y.
    Mike G.
    The look fantastic.
  22. Culprit
    509
    Santa Ana, CA
    Ian
    The OEM material is PMMA (acrylic). According to Wikipedia, the accepted index of refraction for acrylic is 1.490-1.492. The main component of the resin I use is Dicyclohexylmethane, which has an index of refraction of 1.474, so the delta is just 0.016. The inner lens is re-used. So I'd say the visual impression between the two is virtually identical. :)
    ShineKen, 308 GTB and drbob101 like this.
  23. Culprit
    509
    Santa Ana, CA
    Ian
    Thanks for all the input guys. I'll have a set up on eBay as well. Let me know next time anyone gets a bad rock chip or wants to convert to the clear lenses.
  24. ddg599
    ddg599 Rookie
    Nov 23, 2021
    14
    Great work and ingenuity. Are they still available? If so, I could use a pair.
    Gregg
    98 F355
