Clicking noise behind air bag | FerrariChat
Discussion in '360/430' started by Rfong, Sep 5, 2007.
  1. Rfong
    Rfong Karting
    Jul 17, 2007
    70
    San Francisco
    Ron Fong
    I have an 03 360 Coupe and occasionally while the car is running, I hear a electronic clicking noise coming from the area behind the passenger airbag. It sounds similar to a higher pitched click that is produced by the turn signal. It clicks at a random pace and sometimes just goes away. Other times, I turn off the engine and the next time I start it up, the click is gone. I may not hear for days, but then it resurfaces for no particular reason.
    I have tried running the car with the AC system off, same thing for the radio, but no luck. It doesn't sound like it is a short in a speaker wire, but I am having the car checked by a stereo shop this week while installing a new sound unit.
    Anybody have any ideas? Do you think anything harmful is happening?
    Speaking of the turn signal, has anyone tried to change the sound of the turn signal indicator? That ngalk, ngalk, ngalk sound is very un-Italian.
  2. ferrarilou
    ferrarilou Formula Junior
    Apr 13, 2004
    513
    US
    Lou Menditto
    I just had a similar issue. Turned out to be a bad turn signal relay. Pitch was different because it was on its last legs. While the thought of having it die and get rid of the OEM ngalk was attractive, I was worried that then my turn signal wouldn't work at all. All fixed now.
  3. Rfong
    Rfong Karting
    Jul 17, 2007
    70
    San Francisco
    Ron Fong
    FerrariLou, did it happen even when you did not signal to turn? Did the dealer fix it, or did you do it yourself? If so, where did you get the part?
    Thanks for your help.
    "Curly from the 3 Stooges made that same noise, Ngalk, ngalk, ngalk!"
  4. ferrarilou
    Apr 13, 2004
    513
    US
    Lou Menditto
    Yes, it made the noise even when the turn signal was off. Typically during the
    first 20mins of driving, but was intermittent. In fact, it clicked more
    often without the turn turn signal being on - very annoying.
    While I had my suspicions, the
    dealer made the final diagnosis and changed out the part.
    From the invoice, it appears it was $127 in labor, though I don't
    see the charge for the part.
    Lou
  5. Rfong
    Rfong Karting
    Jul 17, 2007
    70
    San Francisco
    Ron Fong
    FerrariLou, it appears you have solved the problem for me - this FChat stuff is great.
    I'll get into the fuse/relay panel in the front trunk tomorrow and see if I can isolate the clicking noise to the turn signal relay. If that is the culprit, Ricambi has the part for $170.00 #164369.
  6. ferrarilou
    Apr 13, 2004
    513
    US
    Lou Menditto
    Don't forget to also check the other relay, #171798
    I think this second one is really the one at fault.
    Lou
  7. Ferrari Rebel
    Ferrari Rebel Karting
    Dec 27, 2006
    180
    Houston, Texas
    Ferrari Rebel
    Guys, thank you! I'm glad I found this thread. I thought i was crazy hearing things when I was driving my 06 430. I'm going to bring the car to the dealer to see if they can confirm this is the issue with my car.
  8. RayJohns
    RayJohns F1 Veteran
    7,930
    West Coast
    Ray
    I get that clicking from time to time in my 360 as well. I seem to remember that if you change the vent control from the upper/lower setting to the upper only, that it stops. I could be wrong about that. You might give it a try and see if it has any effect on things. It may be that there is also a relay in there that controls which vents open/close (but I don't know for sure).
    Ray
