clicking noise LR tire area | FerrariChat
Discussion in '360/430' started by jackgt, Mar 3, 2018.
  1. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    499
    california
    Jack
    I have a clicking noise LR tire area. It sounds like a rock or nail in a tire but clicks faster than the revolution of the tire. Does it in forward and reverse under a light load when JUST starting out. I can not hear it after 5 mph. I an not jack the rear of the car and listen now, just hoping someone has had the same problem.
  2. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    Sounds a little like when I had a bad wheel bearing.
    sparetireless likes this.
  3. BrettC
    BrettC Formula 3
    Aug 13, 2012
    1,977
    Calif
    Brett
    cv joint noise? see if you can see any grease around the cv joint area on the pan...
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,652
    Central NJ
    Dominick
    I would guess CV joint as well
    Sent from my Moto G (4) using Tapatalk
  5. jackgt
    Jan 27, 2015
    499
    california
    Jack
    I replaced both outboard boots and they looked good. I is more of a tap tap like a nail in a tire. I hope I can duplicate it on the rack
  6. honda.vfr
    honda.vfr Karting
    Jun 22, 2012
    134
    Ostrava, CZ (EU)
    Milan Pukl
    Try to look at and behind the wheel center cap, if it is not broken , or its metal ring..
  7. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,538
    Wheel bearing
  8. blackbolt22
    blackbolt22 F1 Veteran
    Sep 25, 2007
    5,752
    Boca Raton, FL
    Mr. Anderson
    I had a similar annoying noise. It could only be heard at low speeds. I traced it to right front tire by having my buddy run along side of car listening for it.
    Turns out part of the tire changing tool broke off inside tire and it was clanging around at low speed but centrifugal force held it against inside of tire at speed.
