Clicking noise on takeoff | FerrariChat
Discussion in 'Technical Q&A' started by Sigmacars, Sep 3, 2024.
  1. Sigmacars
    Sigmacars Formula 3
    1,218
    My 328 makes a clicking noise when I drive off a very short click I went under the Car but nothing is loose
    What should I look for next
  2. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    Is it a one time click or a periodic clicking noise?
  3. Sigmacars
    Sigmacars Formula 3
    1,218
    Just a one time short click right behind the driver side from the back
  4. wmuno
    522
    Wilmette, Illinois
    Bill Muno
    One short click could be some play in a CV joint or a spline on the clutch. Also, check the right rear brake caliper to make sure all the fasteners are OK. I don't have any direct experience with this particular model, but I hope these suggestions give you somewhere to start.
  5. BAK5150
    BAK5150 Rookie
    Aug 24, 2024
    24
    London
    Burhan
    Of possible I would also suggest having someone outside the car as you take off trying to listen and somewhat pinpoint the noise
  6. Sigmacars
    Sigmacars Formula 3
    1,218
    Thank you Guys I never looked at the brake caliper yet I had the car on my lift in gear and there is no play when I turn the wheel by hand
  7. DavidB_SD
    DavidB_SD Karting
    Sep 7, 2008
    64
    San Diego, CA
    David B
    I had a similar problem on my 308 (clicking when going from a stop). The 6 bolts fastening the CV joint to the transaxle output flange (or the stub axle, don't recall which end was loose) had started to back out. They weren't visibly loose and trying to inspect them by hand didn't show anything but when I re-torqued them, some were loose. I haven't had a problem since I re-torqued them. I added some inspection paint for good measure.
    Good luck, hope this helps.
    -David
  8. ago car nut
    ago car nut F1 Veteran
    5,502
    Madison Ohio
    David A.
    Drain gearbox oil into paint filter, look for anything unusual. Also on the magnetic drain plugs.
