Clicking sound in rear | FerrariChat
Discussion in '456/550/575' started by rossodino, Jun 27, 2011.
  1. rossodino
    rossodino Formula Junior
    Dec 16, 2007
    476
    corona del mar, ca.
    bruce sansone
    I am hoping someone knowledgable could help out friend of mine who just got a 2004 575m last week. We noticed when he first drove the car a clicking noise coming from the rear of the car. It seems to happen just at first when the car accerlates or goes into reverse then. it disappears, any ideas.
  2. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Could be lots of things but firstly I would check that his wheel nuts are done up correctly. Then I would check that his cv boots are in tact, then I would look at the discs to see if there may be a stone stuck also see if there are any stones stuck in the tyre similarly nails or sticky tape. Clicking usually means something is turning particularly does it speed up the faster you go.
  3. rossodino
    Dec 16, 2007
    476
    corona del mar, ca.
    bruce sansone
    Thanks for your reply. The wheel nuts are secured, the car was on a lift over the weekend and you could hear the clicking just by moving the wheels forward. The sound disappears quickly once your start moving. It's going into the shop tomorrow so we will see what they find, I just wondered if anyone had a similar occurrence.
  4. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    #4 166&456, Jun 28, 2011
    It could be LSD chatter. Does it happen when turning or also when totally straight? If it only happens in corners at slow speeds then you need different gearbox oil or add friction modifiers, do a search within this forum on these terms, you will find plenty.
    Be aware if the sound also happens going straight. A known issue with these cars is that the clip holding the internal reverse gear in place can snap if reverse is abused; which can eventually lead to the gear falling into the gearbox! This event will munch it.
    I don't know however whether this condition pre-announces itself with any sounds. Does anyone know? And perhaps the condition of this part can be endoscopically checked?
  5. rgm35
    rgm35 Formula Junior
    252
    Valley Forge, Naples
    Rick
    I had this same exact issue with my 575 when I 1st purchased. I took it to Algar Ferrari where they were quite familiar with the issue. Apparently it is somewhat common on the 575. I just pulled the invoice from my file and following is a description of the repair:
    Technician removed both rear axle shafts and applied loctite on axle shafts. Technician then installed 2 new axle nuts and torqued bolts and reassembled vehicle.
    All I can say is it worked. I never had the clicking sound again.
  6. PAP 348
    Dec 10, 2005
    100,213
    Mount Isa, Australia
    Pap
    Interesting. Thanks for sharing. :)
  7. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    That repair sounds very plausible, I believe I had a BMW once that indeed made a 'tinging' sound when the load on the drivetrain changed direction. It was solved in a similar manner.
  8. [gTr]
    [gTr] Formula 3
    Mar 11, 2008
    1,040
    Hamburg, Germany
    Makes sense to me. Had the exact same problem with my S2000, which apparently was common for the early cars.
  9. rossodino
    Dec 16, 2007
    476
    corona del mar, ca.
    bruce sansone
    The axle shafts makes sense, I will pass this along to my friend to relay to his mechanic, thanks for the comment.
