climate control | FerrariChat
climate control
Discussion in 'Technical Q&A' started by 95spiderman, Jan 2, 2010.
  1. 95spiderman
    95spiderman F1 World Champ
    17,673
    ny
    i understand that automated climate controls use the a/c compressor when set to cool the cabin in hot weather but what happens in winter? in all my cars, the auto setting also seems to turn the a/c on even during winter unless i also press the econ button. does this matter if i want to maximize fuel economy? thanks
  2. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    what model are you referring to? on a 360, i know the a/c compressor needs to be on to get really good,hot heat. if you push the a/c button in the compressor does go off and will maximize fuel economy but the heat isn't as hot
  3. 95spiderman
    17,673
    ny
    i have audi, vw and porsche but ive seen this on most modern cars. what i dont understand is why wouldnt heat get as hot if the compressor is off?
  4. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    It's Italian. This was driving me crazy when I first got my 360. It is counterintuitive.
    It is what it is.
  5. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    698
    Delray Beach FL
    Russell
    I think most cars run the compressor when in auto climate control mode, to stop the compressor run it system in ECON mode, you will get heat and ambient air but no cool air.
    Old or cars without auto climate typicaly have a button to turm the compressor off and on.
    Russell
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The A/C is used as part of the defrost/defogger (a dehumidifier uses the same technology) on most modern cars and is always on for some.
  7. 95spiderman
    17,673
    ny
    does compressor effect fuel milage?
  8. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,744
    Everything that consumes power effects gas milage. This includes big loud stereos, high watage driving lights,...
  9. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Totally agree!!!
  10. sierrafoxtrot
    sierrafoxtrot Rookie
    Dec 17, 2008
    47
    North Texas
    Derek
    #10 sierrafoxtrot, Jan 3, 2010
    The 575m, along with most all late model Fcars, use an electric water pump to circulate the water throught the heater core. If the climate control "On/Off" switch is Off, the compressor and the water pump are Off, hence you do not have heating or cooling. You can run the blower, though. I believe that the climate control logic is the same on all cars with the electric water pump, but I could be wrong. It should be noted, that on the 575m, the heat soak throught the firewall will keep you warm down to about 40F (not helpful in a Texas summer)!
  11. sierrafoxtrot
    Dec 17, 2008
    47
    North Texas
    Derek
    #13 is the pump, BTW. Only $329.35!!
  12. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Climate control is more than cool/heat but requires the a/c in winter to dry the air before warming it.
  13. Rifledriver
    37,288
    No Ferrari since the TR has used Italian climate control. Blame rests on the Germans and Americans.
