Climate fan chirp | FerrariChat
Climate fan chirp
Discussion in 'Technical Q&A' started by fou, Apr 24, 2010.
  1. fou
    fou Formula 3
    Feb 1, 2007
    2,232
    Central Virginia
    Call me the breeze
    No bashing please, this is a Land Rover question, but I know a lot of you guys have Rovers as daily drivers. I tried some Rover sites to no avail.
    One of my LR3s has an obnoxious chirping noise coming from the climate fan located behind the glove box. I tried getting some silicone spay on the shaft without removing the unit, but alas, no go. Anyone come across this problem and stumbled onto an easy fix? If you did remove the fan, do you have any instructions to avoid a trip to the dealer? many thanks
  2. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    I have a similar problem on my Lexus RX300...sounds like a little bird in there.
    Bump!
  3. culo951
    culo951 Karting
    Apr 24, 2010
    97
    Pataskala, Ohio
    Adam Culp
    I don't have a LR3 but I did have a discovery II. I am not sure if yours has a cabin air filter, but usually it is between the cowl and the fan, try taking that out and seeing if some debris has gotten down into the fan that way. While you are there you might as well replace the filter.
    Anyway, I don't know if that will solve the problem but its worth a shot!
    Adam
