Clip replacement - plug wires/ cam covers | FerrariChat
Discussion in 'Boxers/TR/M' started by vincenzo, Nov 28, 2018.
  1. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    After a bit of drilling, the old plastic clip came out of the valve cover.... no problem.
    The replacement clip’s post fits in the cam cover’s hole just fine. Then, a pin is driven down the clip’s hollow post to expand it securely into the cam cover.
    ...or so I thought.
    The first try broke the clip. It seems as though the driven pin is way too large of an OD for the clip. Trying to drive the pin just shattered the clip.
    Can anybody shed some light on the proper technique for mounting these clips into the cam covers?
    Thanks in advance!
    Vincenzo
  2. ago car nut
    ago car nut F1 Veteran
    5,502
    Madison Ohio
    David A.
    It has been so long. But I don't remember driving a pin in. I believe (memory not so good) they just pressed in!
  3. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    I lub the pins and holes with silicone grease and use an over size punch.
  4. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Do you often, or rarely break a clip when you use silicon?
    Would a press be less likely to shatter the clip vs punch and hammer?
    I bought a spare and would hate to break it - don’t want to have another shipping delay!
  5. todd6363
    todd6363 Formula Junior
    Jan 20, 2007
    270
    Ohio
    Todd
    vincenzo likes this.
  6. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Just a follow-up.
    I carefully chamfered the pin, used silglyde and used a press to ensure a straight drive. No luck. More pressure would have split the clip.
    Plan B:
    Toss the pin in the trash, and secure the clip with a slight bit of isocyanate glue. Problem solved.
    Note that with a pinned clip, the clip must be drilled out.... so drilling out a clip secured by glue is a non issue.
    Cheers,
    Vincenzo
    BTW: Todd, that pic looks great! What did you use to polish your headers?
  7. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,959
    The Cold North
    Tom
    Those pins do not fit as designed. After busting a few, I sand or file them down to fit.
    turbo-joe likes this.
  8. todd6363
    Jan 20, 2007
    270
    Ohio
    Todd
  9. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,541
    romano schwabel
    looks great
    like polished
  10. ferrarioldman
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    Very rare that I break one.
  11. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    I find that trying to install the clips with the cam covers in place in an exercise in frustration, as it it extremely difficult to get a good shot straight shot on the pin with a punch/hammer. I usually only replace the clips during a belt service with the cam covers on the bench. Also putting a bevel on the end of the pin helps get the pin started, and then a lot of force is needed to drive the pin in flush.
    All of the remnants of the old pin and clip must be removed from the bore of the hole in the cam cover in order to get the pin to drive in flush. I haven't tried it, but if I were replacing the clips with the cam cover installed, I would machine the pin down to such a diameter that it went in with less force. It doesn't take much to hold the clips in place. I have never seen them pull out of the cam cover. They just break when installing plug wires due to the fact that they get brittle with heat and age.
    They should be replaced every time the cam covers are off.
  12. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    ...but a drop of superglue is so much less frustration. No visual change. Either way (pin or glue) they need to be drilled out.
  13. turbo-joe
    Apr 6, 2008
    9,541
    romano schwabel
    until now I not found good superglue what is heat resistant. better use silicone or the glue for windshields ( sorry, don´t know the english word :( )
  14. ferrarioldman
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    Those holes are actually threaded so if the plastic clip is not brittle they can be "screwed" out. Otherwise you are correct that you have to drill them out.
  15. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    no threads in my ‘90.
    Good points on thermal strength retention.
    Very little data published (that I found). This info claims that strength degradation starts at about 100C. This is ‘about’ the max temp these valve covers should see since the inner aluminum is only splashed with oil and the aluminum rapidly dissipates the heat.
    If they do come loose - going back in with an epoxy seems like a good idea.
    If they do loosen with heat - I’ll follow up.
  16. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
  17. turbo-joe
    Apr 6, 2008
    9,541
    romano schwabel
    could work fine, but if the clip will break it is hard to get the rest out again, so silicone is easier to remove I think
    in my 87 there are also no threads
