Clock | FerrariChat
Clock
Discussion in '206/246' started by nerodino, Nov 24, 2009.
  1. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    #1 nerodino, Nov 24, 2009
    I bought this clock hoping that i could change the guts from it in to mine (which has a broken main spring!) but to no avail, it's just too different from the Dino clock.
    I suspect that it's older than mine as it doesnt say the word 'Electronico' on the face and also is of better construction with a brass case instead of the OEM plastic one.
    Does anyone know what model (maybe earlier series Dino, mine is a 74 car) of Ferrari this may have come from?
    Then when i know i can post it for sale as i am sure somebody out there needs one and i will continue my quest for the correct one!
    Kindest Regards, G P.
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #2 synchro, Nov 24, 2009
    If the can size is the same, then what I do is use the new casing and internal movement and place the face, hands, bezel and chrome securing ring on this working assembly.
    PS - The only issue that I've found is that some of the older faces had the two mounting screws positioned further inwards.
  3. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Scott,
    Problem is the bezel is different and the worst thing is that the adjustment knob on the older clock is very different in as much that it is fitted on the shaft with a tiny screw.
    The original clock adjustment i believe is push fitted on.
    The face fitting is the same albeit the numerals are different in size as you can see.
    G P
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
  5. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Tony,
    Even that tw*t Paul Daniels couldnt fix my clock so unless they are more than magicians theres no point!
    P. S. Hows the mansion coming along?
  6. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    let me check my clock which doesn't work, I am referring to the brass case clock. If it works then I wuld be interested in purchasing it. '72 dino, #1532. I am traveling until next month but will contact you upon my return.
    clay
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Graham
    They can repair themand have in housepeople to make specialist components.
    worth a try in my book!!
    Tony
