Clogged targa drain | FerrariChat
Clogged targa drain
Discussion in '308/328' started by wildrnesxperienc, Sep 12, 2022.
  1. wildrnesxperienc
    Apr 9, 2022
    193
    Los Angeles, CA
    Need to wash my new ‘86 328 GTS but the passenger side targa drain is clogged. There is currently some water down in it from the wash the dealer must’ve given it. I found out there was water when I ran a weed eater string down into the drain as far as it would go, which is about 19” from the drain, making the clog inside the A pillar. What’s the best way to unclog something like this?
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Compressed air often works great.
  3. Imatk
    Imatk Formula Junior
    May 6, 2007
    769
    I used a carpet tape for something like this on a different car with a sunroof before. Worked really well.
  4. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
    Can you post a photo of which drain you are referring to please.
  5. Rifledriver
    37,103
    There is a hole in the trough ahead of the top seal right at the A pillar.
    Rosey likes this.
  6. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
    I'll have a look at mine now. Thanks
  7. wildrnesxperienc
    Apr 9, 2022
    193
    Los Angeles, CA
    I just tried a washing machine brush on a flexible cable. Couldn’t get it all the way through. Only about 12 inches in. Tomorrow a speedometer cable comes, I’ve read some have had luck with that. I’ll update. If it doesn’t work then my mechanic is going to fix it.
  8. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    458
    Mexico
    Rod C
    How about going from bottom to top?
  9. wildrnesxperienc
    Apr 9, 2022
    193
    Los Angeles, CA
    I tried that with the trimmer string but not the metal wire. Assuming this is the hose? Seems like it’s hanging out a long way no?
  10. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    That could be the A/C condensate drain hose..
  11. wildrnesxperienc
    Apr 9, 2022
    193
    Los Angeles, CA
    Ah so does anyone have a picture of the targa drain end?
  12. P4AntonLM
    P4AntonLM Karting
    Dec 31, 2007
    156
    Austria
    Anton Schicho
    The hose in the photo is the right one, you will find them on both sides.
    The AC drain hose is in the bottom center forward.
    maurice70 and wildrnesxperienc like this.
