Closing your rear engine cover question | FerrariChat
Discussion in '308/328' started by Rosey, May 12, 2017.
  1. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,815
    Australia
    Mark R
    The other day it dawned on me that I always need to close my rear engine cover by pushing it down to where it just touches the pins and then pushing down hard on one side and then the other with my palms.
    Clicking one side and then the other.
    I have never been able to close it by just letting it fall or by closing firmly and have both pins catch at the same time.
    Do you guys also close your trunk the same way (i.e. thats how they are designed) or has mine gone out of alignment slightly after all these years?
    Cheers
  2. 4re308
    4re308 F1 Rookie
    4,886
    Woodstock, GA
    Mitch D
    I would never slam the lid, I do exactly as you do. Press one corner down at a time and clicking the other side till closed.
  3. bertspeed
    bertspeed Formula Junior
    Sep 19, 2009
    308
    yes,I do it exactly the same way. Although my front lid needs to be dropped and pushed at the same time which does not seem right.
  4. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    Our Ferrari Area Technical Manager showed me the way they were instructed to close them at the factory.
    Put your arms shoulder width apart, insert hands under the decklid and curl your fingers under the edge that is about 3 inches forward. Hold the decklid about 12" above closed position, "pump" it once and then let go. It should close.
    "PUMP" is the act of quickly raising the decklid to almost fully open, quickly bringing it back down to about 12", repeat but on the down stroke let go of it at the 12" level and it should close properly.
  5. Rifledriver
    37,130
    That's for the front on cars without the gas strut.
    For cars with the gas strut I kind of throw it down. If correctly adjusted it latches.
    On the rear I also throw it down with hands clear prior to contact. Pressing them closed causes dents and cracks.
  6. alfavirusnz
    alfavirusnz Rookie
    Feb 17, 2017
    3
    Christchurch, New Ze
    Richard Jones
    I let my engine cover drop from about a foot with a slight downwards assistance - not quite a throw but along those lines. It never fails to catch.
  7. barabba
    barabba Formula Junior
    Jun 7, 2007
    689
    Ticino / Zurich
    I don't slam the cover but sure do it quite firmly. I never press the two sides. I don't think that using the proper factory procedure would do.
  8. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,325
    #8 Iain, May 12, 2017
    In Indi tech once showed me that the preferred method was to "throw it down" from about 12-18 inches. If you can't do that then something is out of whack. If you have to lean on the hood to make it latch then over time you risk deforming the metal.
    Rear deck and latch alignment is a matter of careful adjustment - same for the release cable. its entirely possible that if the deck has been off a couple of times (eg for servicing) it maybe not as well lined up as it once was.
    Look at the shut lines. If they are uneven then look to the hinges. If they are OK & alignment is OK & its still difficult to close then maybe you need to look at the latches. If the latches are badly adjusted then you may wear them so its worth correcting any mis-alignment issues.
    Rule #1 for a DIY-er when adjusting the latches (IMO) is to take the rear lights out. If you do that then you can adjust things safely without finding yourself in a position where you can't unlatch the hood for some reason. It also allows you to clean the lights out & the surrounds as well.
    Its also possible to adjust the latch cable such that there is a little slack between the two latches. This means that when you pull on the lever it unlatches one side momentarily before the other (rather than both together).
    This significantly reduces the stress on the cable and the latch lever & housing (and makes it much easier to unlatch the thing).
  9. mwr4440
    57,988
    Bavaria, The 'Other' Germany
    Mark W.R.
    Even if pressing on the 'tip' of the 'spoiler.'
    The 'flat' parts, I understand.
  10. 4right
    4right F1 Rookie
    I don't have gas struts, so I let mine drop from about six inches. If that doesn't work, I press down on the lid on both sides but never at the end of the deck lid where denting can Result. I press where the deck lid starts to angle up towards the roof, between the end of the lid and the antenna.
  11. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Wow, mine is totally different. I don't have any kind of that junk. I just have a solid rod that holds it in position.
    Once I slide the rod away from the hold open position I just let it slam! :):)
  12. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    ^^^this [emoji12]
  13. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    If I have a friend handy, I get him to put his fingers in about two inches and then slam the **** out of it...effective :)
  14. dflett
    dflett Formula 3
    1,632
    NY
    David
    I do the same as the op. Drop it but then push down on each side to latch but I push on the buttresses, not any flat sheet metal. Never had a problem with dents.
  15. Albert-LP
    Albert-LP F1 Veteran
    8,177
    around Modena, Italy
    Alberto Mantovani
    The closing procedure For an engine lid wit gas struts is this:
    With the lid on the highest position (fully opened) place your left hand close to the lid left end and your right hand close to the lid right end.
    Lower it very slowly until it will be one foot and an half or two from the closing position.
    Now pull it down very quickly, slamming it down: The trick is never push but just pull. Of course you have to pull it down with the same force with both hands and try to learn which is the correct closing speed your lid needs, starting with lower speed and repeating the maneuver with higher speed if it doesn't work.
    Better avoiding to push: The lid is very thin and easy to damage if you push it down
    Ciao
  16. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,328
    Montana
    Kim
    Front lid - let it drop from a height of 12", latches perfectly with a solid "thunk"
    Rear lid - lower it gently and then latch by pushing down on each side of the buttress.
    Drivers door - use my left hand to open it.
    Passenger door - use my right.
    Use my left index finger to push button on the garage door opener. :)
  17. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,044
    Coolum Beach AUSTRALIA
    Karen H.
    I do hands right out on the buttress, never near the flat metal.
  18. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Place the palms of each hand flat against the top of the deck lid. One on each side of the Ferrari emblem. Slam as hard as you can. Make sure to wear class ring:)
  19. Qvb
    Qvb F1 Rookie
    2,848
    Newport Beach Ca.
    John Dixon
    The sides of the buttresses will distort over time if they are used to latch the lid. The lid should be gently slammed.
  20. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,815
    Australia
    Mark R
    Quite a few differences of opinion on this one.
    With no other brand could there be so much discussion on a relatively simple topic such as closing an engine cover.
    Love it !!
  21. speedcat
    speedcat Karting
    Jul 26, 2011
    159
    Calgary, Canada
    Any tips on adjusting the latches? I just replaced my 328 hood release cable and it won't latch without a little push. TIA
  22. scudF1
    scudF1 F1 Rookie
    2,918
    Long Island, NY
    Billy
    I'm sure you will find that kind of topic on Porsche forums.
  23. 4right
    4right F1 Rookie
    I don't have access to my owners manual, I wonder if there are any instructions related to this topic?
  24. Rifledriver
    37,130
    No. It would take too long and my arthritis doesn't let me type that kind of dissertation.
  25. Rifledriver
    37,130
    If there is I am sure it is worthless.
