"Clutch alarm"? | FerrariChat
"Clutch alarm"?
Discussion in '360/430' started by LetsJet, Jul 10, 2004.
  1. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I've got a 355 F1 Spider and I was looking at the Manual / F1 thread and this "Clutch alarm" came up. I'm not familiar with any "Clutch alarm" and I can find nothing about it in my manual.
    The one post references ch. 3 p 14 but I don't have it.
    Anyone care to elaborate on this?
  2. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    I have a 360. Why would it be on the same page in a 355 manual?
  3. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Obviously it wouldn't....
    I appreciate the help but it's not in the manual
  4. alanhenson
    alanhenson Formula 3
    Dec 2, 2003
    1,357
    My clutch alarm used to go off in my 355F1. That was just before I had to replace it at 10K miles. The previous owner drove it in auto way too much.
  5. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I'm still hoping a 355 F1 owner can elaborate on this. Anyone have any documentation on this feature? If a 360 owner could pdf the page referenced, I'd appreciate that also...
    ..... come on guys an actual Ferrari question on FChat!
  6. SrfCity
    SrfCity F1 World Champ
    Hmm, I had an alarm go off a while ago and thought that that was what it was in my 360. I wasn't sure if it was just an overheat though. The dealer said if it happened again they'd annalyze it and possibly adjust the parameters to get some more life out of the clutch. It hasn't occurred again. I suspect that a new clutch may be due down the road :(
    Here's the thread:
    http://ferrarichat.com/forum/showthread.php?t=23197&highlight=360+clutch
  7. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    That's helpful, thanks.
    But. I'm still looking for a Ferrari document describing this. Also, if you start in second as is sometimes recommended, wouldn't that require more clutch slippage before fully engaging? Though, the alarm goes right off if I switch to second. There should be a way to tell if the clutch is fully engaged. In a normal manual transmission car you could depress the clutch fully at snail speed and not burn the clutch out.
  8. Rifledriver
    37,335
    See page H96 Vol. 3 of the 355 shop man. 2nd gear starts were as you say suggested however only for the sake of smoothness on take off or Greater safety on slippery surfaces. FYI I got to know a man who was an engineer with Ferrari and was the one who was tasked with doing the long range durability testing on F1's. Ferrari's position was clutch life was the same on both trans. types. He stated to me his report said clutch life was 40% less on F1's.
  9. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    There is a guy in NW on this board (willis360) with an F1 360 and 26K+ miles on his original clutch. How can that be possible. I have seen most to be replaced around 8-11K and some as low as 5k... How can you preserve the clutch like that?
  10. Rifledriver
    37,335
    Drive down the freeway
  11. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I'm going on 20,000 with a 99 F1, no problems yet,
  12. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    Is that mostly freeway driving?
  13. SrfCity
    OK, just got back from chatting with the dealer. The beeping is because of excessive slipping and overheat. They said that they can make an adjustment on the clutch so that it grabs a little quicker but would be a little more jerky on take off. After talking to them I doubt mine requires a new clutch and it's more of an over heat issue. The dealer said don't worry about it unless the beeping becomes more frequent.
  14. alanhenson
    Dec 2, 2003
    1,357
    Drive your car up a hill from a stop and if it beeps, your clutch is going out. This is how I knew mine was failing. Changed mine at 10K miles. The guy before me must have used the auto too much. Shift in sport without auto at higher rpms if you want the clutch to live longer. Harder, firmer shifts extend clutch life. I shift mine at about 8K as often as possible. Oh what a feeling.
  15. SrfCity
    Jeez, are you serious? That's how the beeping started in the first place. Crap!
    What can I expect to pay for a new clutch if I need one? I've got an estimate from the dealer.......
  16. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Actually, I hate driving on freeways. Most of the driving's done on local backroads. It's just more fun.
