After 3 1/2 months abroad back on my post! Question: How does one bleed the clutch on a 4200 Spyder? Engine has been out, so system is empty. Does the system get bled with the engine running, or static? I don't want to run the risk of disturbing anything else following the wrong method, and the car is not with me right now to try out what works. Help much appreciated! Jack.
More to it than that - requires dedicated SD2/SD3 equipment normally only available to dealerships or better independents Suggest you do searches thru the main Maserati forums in the UK & USA for more info
