George, I realize the correct answer to this question is "it depends" however, what is your "back of the napkin" estimate of mileage on the odometer when a new clutch may be required?
I don't race my car and I don't do launches. The first owner drove the car as a daily driver so I'm hoping to go to at least 60K. The general rule is 10% clutch wear for every 10K of miles driven.
In my case, at 87,000 km, a list of items to be replaced. A lot of elements for me, I wonder if there must be so many. Part qt Name 230426 1 ENGINE FLYWHEEL 201755 8 SCREW 222277 1 COMPLETE CLUTCH 11194379 9 WASHER 11194379 9 WASHER 216771 9 SCREW 201935 1 COMPLETE SENSOR KIT 181837 1 SCRAPER RING 208014 1 SEAL RING 181838 1 SEAL RING 234943 1 COMPLETE THRUST BEARING 181828 1 SEAL RING 154507 1 RING 181836 1 SCRAPER RING 182955 2 STUD BOLT 155207 2 CLUTCH THRUST PLATE PRELOAD SPRING 182952 1 BEARING MOUNTING FLANGE 16286224 2 SCREW here is video Here in the video you can see with the screws only that the clutch, pressure plate and bearing have been replaced Regards
