Clutch dead in 348 Spider | FerrariChat
Discussion in '348/355' started by crashwilliams, Oct 3, 2006.
  1. crashwilliams
    crashwilliams Rookie
    Nov 24, 2005
    39
    Oklahoma City
    Robert Williams
    While driving today my clutch pedal got soft and then no pressure at all. The clutch was very strong and exhibited no signs of wear. On the bottom side or the clutch housing is a perforated plate with some fluid like brake fluid on it. Any ideas or suggestions
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Could easily be a blown slave/clutch throwout bearing.
  3. LSU348
    LSU348 Formula 3
    Dec 19, 2003
    1,047
    Sugar Land
    Brake fluid is the hydraulic fluid used on the clutch...same resevior. Look at your brake fluid resevoir and see if you have any left. YOu may have had a leak and just pumped the clutch dry. May not be a terribly expensive fix. Hopefully you will be able to find your leak easily.
    Resevoir is under the front bonnet, left side, under the larger accessory cover (same cavity as the battery switch) all the way to the back.
    Check your brakes to make sure a line has not been sliced or ruptured.
    See that hose with a bolt on the end of it? Do not take that off :)
    Do not get that fluid on your paint (you probably know this....just trying to prevent a disaster by pointing that out). If you get it on there wash it off immediately.
  4. Ski Guy 348
    Ski Guy 348 Formula Junior
    Mar 29, 2004
    261
    Greenville, SC
    Jay M.
    I vote for a slave problem...Mine has been addressed several times.
  5. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    A few times? How many times can it fail on ya? Mine is the still original slavebody/seals in the car. :)
