348 - Clutch flange | FerrariChat
348 Clutch flange
Discussion in '348/355' started by A348W, Oct 5, 2021.
  1. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    Just replacing my clutch and also need to do the clutch release bearing.
    I have the old style and need to get the newer style to get a bearing.
    So I need to replace the clutch flange and want to confirm if Ferrari part no. 168589 will fit? A post I’ve seen implies it needs modification to block some oil ways but I c as my find anything difinitive.
    I have a line on a used part so would save a lot over a hill one.
    many thanks.
  2. AceMaster
    Feb 6, 2009
    34,761
    Ontario, Canada
    Did you check with Daniel at Ricambi? He would know the answer
  3. fatbillybob
    Aug 10, 2002
    28,634
    socal
    Probably if you search for the flange on one of the sites like eurospares it will say flange xyz superceeded by #1234567. There are no old flanges you can buy from the reputable places. As far as the holes to plug there is aluminum threaded rod that comes with the flange if the areas have not been blocked out. If not you just run the threaded rod in there, peen them over, and it plugs up the extra holes. It is totally obvious when you see it.
  4. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    Thank you.
    Lots of referencing of Ferrarparts.co.uk and hills engineering.
    The hill part is stated to replace part number 168589, but that’s not listed on ferrariparts for the 348; only the 355.
    Good to know re the threaded rods.
    For the price of used parts; think I’ll give the used oem part a try!!! What could go wrong!!!!!
  5. fatbillybob
    Aug 10, 2002
    28,634
    socal
    Well the flange shaft has to be perfect. Scratches will eat the T/O bearing seal and you will get leaks.
    A348W likes this.
  6. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Personally I would never use a used one, its like using a used cam pulley. out of true, micro cracks you can't see, seal grooved damaged from improper seal install, the list of long of issues. To ensure I do it once I would spend the extra 30%. Were not talking thousands here. But everyone has their own method, Just bringing it up is all. Best of luck with your path!
    26street likes this.
  7. Pit 348
    Pit 348 Rookie
    Dec 31, 2015
    11
    Erftstadt, Germany
  8. AceMaster
    Feb 6, 2009
    34,761
    Ontario, Canada
    I thought the Hill was two parts, inrecall something like that when I was investigatonf my TO bearing (which luckily only turned out to be just a chewed up seal).
    I still suggest you contact Daniel at Ricambi.
  9. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    Thank you yes; I’m familiar with both sites and have been using them as reference. Clutch will be from ferrariparts.co.uk.
  10. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    2nd hand oem is a saving of about 300% (£300) over a new hills parts.
    They should never wear out or sustain any damage so as long as said above, the shaft is perfect I see no issue.
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Makes sense but unless you can touch and see the part first hand before you buy it it's kind of tough is all. If you buy used make sure they have a return policy.
    Sent using FerrariChat.com mobile app
  12. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    493
    Victoria, B.C, Can.
    John Glen Wesanko
    I have a 1990 348ts and recently replaced the bearing on the clutch "slave" cylinder which I purchases from Superformance. Are they not still available ?
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    He's looking for a used one which is cheaper and not a bad strategy. :)
  14. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    There are two different size thrust bearings. Both bearings are available, but you would have to get them out if the carrier; not easy.
    Most people buy a new carrier with the bearing already in it. Only the larger size is available. The flange has to match; so if you have the smaller size you need as new bigger flange (what I’m discussing). They are readily available from Hill but at circa £400 or some nut price from ferrari. I have the possibility to get a second hand Ferrari one for not much. Question I’m trying to bottom out is if it will fit; as part numbers vary between aftermarket and oem.
    second hand is a risk if it’s got any damage; but it looks ok do I think worth the punt!!!
  15. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    Sorted in terms of parts;
    Found a new OEM flange at a reasonable discount, and ordered a hill bearing.
    Hopefully have it back on the road next week.
    Ferrarium likes this.
