Is there a substitute part for the clutch hose on Mondial 3.2. This is the hose between the slave cylinder and the hard hydraulic line. Thanks!!!!
https://www.eurospares.co.uk/Parts/108865/Ferrari/New/95235 https://www.redbaycars.com/webshop.html#!/products/clutch-pipe-part-nr-108865
Aw Italian and other typical suppliers have them. They are not braided stainless covered like the oem one, rather they are the same as the reproduced brake lines, with a rubber hose and less visually clean crimped fittings. Might consider putting a heat shield tubing or wrap on it, it is close to header heat which must shorten its life.
