Clutch Master Cylinder Replacement | FerrariChat
Discussion in 'Mondial' started by RichardAguinsky, Apr 21, 2013.
  1. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    #1 RichardAguinsky, Apr 21, 2013
    After all these years of dealing with a leaking clutch master cylinder, I decided to finally replace it. It is incredible how different the clutch feels now. Like a new car. I replaced the slave cylinder with a new one years ago. The pin under the pedal box is what deterred me from replacing it before.
    The Ferrari OEM master clutch cylinder is about $450. The after market ones average $200. I bought mine from Ferrari of New Jersey for $175 plus shipping.
    Here is what I did:
    1) Remove the front driver’s seat. It is only 4 Allen screws.
    Hint: Put a nice padded matt in the floor; you’ll be spending some time down there. You will only be able to use one hand to get the pin out. Be patient.
    2) Remove the brake pedal spring that is covering the cotter pin.
    Hint: Use a string to pull on the hook of the spring towards the rear of the car and a needle plier to unhook it from the chassis.
    3) Remove the cotter pin with the needle plier.
    4) Push the pin with a screwdriver or the end of the needle plier. It will not go all the way through as it will hit the top of the clutch box.
    5) Slide the end of the rod to the side, spin it and the pin will come out.
    6) Now go to the trunk and remove the hose at the master cylinder side. I held it up with a tie wrap so the fluid would not drain out.
    I believe the Mondial 8 has its own reservoir.
    7) Remove the top and bottom nuts that hold the master cylinder. In my case, I used a large adjustable wrench from my plumbing supply toolbox. I had to remove the stop light switch to fit the large wrench.
    8) Pull out the master cylinder. In my case, it was very rusted after years of leaking, I had to hammer it out and use a file to remove the corrosion on the aluminum box.
    9) The master cylinder was very corroded. I did not want just replace the O rings, so I ordered a new master clutch cylinder.
    Note: I bought the o-rings from Guido, but after seeing how bad the cylinder actually was, I decided to buy a new one.
    10) I measured the distance from the base of the old master cylinder to the center of the hole where the pin goes. See the picture below, top one is the new. I then removed the bracket from the old cylinder and placed it on the new one with the same distance.
    11) Installed the new master with standard M8 nuts tightened by hand.
    12) Went back under the pedals. Checked that the hole on the pedal bracket matched the hole in the master. I had to remove the master and readjust, it was off slightly.
    13) Installed the master with two new stainless steel lock nuts.
    Note: I could not find 12 mm M8 nuts so I could use a socket. So I got new 13 mm stainless lock nuts and used the big wrench again.
    14) Placing the pin back in is the tough part as it has to be done with only one hand. I used one hand to guide the pin in. I used a coat hanger wire with the end bent in an L-shape to push the pin in from the top.
    15) The cotter pin was easy to place. Bending it was not easy as the pin spins.
    16) Put the brake pedal spring back.
    17) For the bleeding, I removed the plate behind the rear seats, easy to access the bleeding nipple. I use Prestone Dot 3 Synthetic.
    18) Bleeding was longer and harder than expected. I used the hand held MityVac and also pumping with the pedal. It took over 1 pint of brake fluid and there were still bubbles. Pressure started at 2” of travel., there was enough travel to disengage the clutch, but it was low. The next day I went to work with the car, it took about 15 minutes of stop and go traffic to get the pedal back to the top.
    Good luck!
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,581
    Argent/Brasil
    Guido
    Congratulations, Richard....Seems that bleeding is always the problem.
    Guido
  3. RichardAguinsky
    Nov 12, 2007
    478
    Richard Aguinsky
    Hi Guido.
    I started with the MityVac hand bleeder. Very little fluid came out. I then switched over to my 12 qt MityVac oil changer and pumped until I ended up with similar vacuum from the hand held one. Lots of vacuum to spare. Even though, not much brake fluid came out.
    What I do not understand is where the obstruction in bleeding is. The hose from the brake reservoir has a large opening. The hole from the tube to the master cylinder is also quite large. The tube from the master cylinder to the slave is large. The slave has a standard bleeding nipple. Brake fluid should flow easily.
    I am very happy now with the way it handles now. I am even thinking in readjusting the pedal so it does not engage so high. Granted, next time I remove the seat. ;-)
  4. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Hello Richard, thanks for taking the time to describe everything you did and to take pictures.
    This article is going in my little black folder under 'Clutch Master'
    Many thanks :)
  5. fgcfire8
    fgcfire8 Formula Junior
    Jan 19, 2008
    459
    Montpelier Va
    Frank Castelvecchi
    I did not pull the seat on mine just did the stand on head while manipulating bent needle nosed pliers suspect seat removal might have been easier
  6. 86mondi
    86mondi Rookie
    Aug 6, 2022
    39
    Virginia
    Frank Buckman
    I can’t for the life of me get that bottom bolt out. I have been unable to get purchase on the bolt. I have tried various socket wrenches, conventional wrenches, and now a crow’s foot wrench. A socket would work if there was a space between the cylinder and the bolt but unfortunately that space is too narrow. I have even tried grinding the outside of my socket wrench attachment in hopes that it would be able to engage the nut but no luck.
    Any advice with pictures if possible.
    Thanks in advance.
    Frank
  7. wilkrod
    wilkrod Karting
    234
    Ocala, Fl
    All,
    Appreciate the write up as I am presently removing my clutch master cylinder, made the job much easier.
    I found it impossible to remove the lower nut with any of my wrenches, crowfoot, stubby, s wrench, etc. There is no clearance for a socket, so I took a deep well 13 mm socket, and ground down a flat so it could get a purchase on the nut, used with an extension, and tapped it on to the nut with a hammer, nut came right off.
    Hope this helps.
    Regards
    350HPMondial likes this.
  8. PeterS
    PeterS Five Time F1 World Champ
    51,359
    Goodyear, AZ
    PeterS
    Awesome you can do this work, hope it looks just as purdy as mine when you are done!
