Clutch not engaing on hard acceleration | FerrariChat
Discussion in '360/430' started by Skidkid, Jul 16, 2007.
  1. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    I was driving my car the other day and had an odd experience. I punched it hard off the line and the clutch failed to hook up well, lots of nasty burned clutch smell. I backed off and it hooked up, then on to 2nd and a repeat of the problem. The car use to hook perfectly so this is new behavior.
    A little possibly important information:
    The car is a 2001 F1. The TCUs have been upgraded. I generally accelerate pretty easily. I corner hard and drive fast but I don't accelerate hard from a stop. I recently replaced the battery so I had the power off. After the startup/learning cycle I drove the car normally, fairly gently on acceleration. The car has 18K miles and the clutch was replaced once by the previous owner.
    The real question is the cause. A few thoughts or ideas:
    1) Is there a learning cycle for the TCUs based on driving? If so, would it keep the clutch from hooking up solidly on hard acceleration?
    2) The clutch may be bad. I have driven it since and it appears to be normal. I do not get any of the typical popping out of gear that has been described may times.
    3) The clutch needs adjusted. Maybe the clutch really needs adjusted a little tighter.
    Other idea?
  2. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,860
    San Jose, California
    I am sure that RifleDriver would have given some invaluable insight into this issue had he not been ran off of this forum.
  3. SrfCity
    SrfCity F1 World Champ
    Try this, as the clutch puter settings may be off. Drive the car around in automatic mode for about 30 minutes while the puter resets itself to default. Then put it back to F1 and see if that does it? This came from a local mechanic who suggests doing this when the car has been sitting and the clutch begins to act up. Let us know if it works?
  4. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    if the problem only happens with high revs, you may have the same problem I outlined a while back on this thread:
    http://www.ferrarichat.com/forum/showthread.php?t=149344
    With the manual gearbox, you can feel more what's going on with the clutch. With the F1, I would think the feeling I describe may be masked to some degree. This may or may not be the case. However, if it is, it may allow the clutch to wear down more, until the problem is worse. Basically, I think it boils down to a worn out (or wearing out) clutch.
    Ray
  5. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Thanks Ray, I will take a look. Unfortunately my first guess is that the clutch is getting thin. I would just drive it until it goes but I really don't want to get stranded so ....
    I guess I need to get an appointment with Brian and take it in.
  6. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    Yeah, if you read that link, I think the problem does stem from a thin clutch disc, which allows the pressure plate to over extend in the resting position.
    Ray
  7. Spinne
    Spinne Rookie
    Jul 16, 2007
    45
    Vancouver BC Canada
    Steven S
    I have a clutch that if new. Only 6% wear and I also have some excessive slip, or so says the dealer. He told me that the plate could be glazed. He also told me to go easy on it.
  8. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    perhaps the gearbox/clutch needs to have that PIS thing (point of initial slip) adjusted also. Isn't that an F1 adjustment using the SD3?
    Ray
  9. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    I had thought of that but haven't had it in since it is fine diving around town. Once engaged it is fine and shifts well so I haven't rushed. I am starting to think that it runs better if I drive it like I stole it.
  10. Stew
    Stew Formula Junior
    Apr 16, 2006
    547
    Los Angeles
    I read the description you gave of yourself on your webpage ! http://spaces.msn.com/members/mikeniday
    "I am flexible, extremely generous, good communicator, and generally try to see the good in people.... "
    You forgot to list that you are also a WHINER !
    If Brian feels a need to defend himself, I'm sure his has no problem doing so.
    Warmest regards,
    Stew ;)
  11. cig1
    cig1 F1 Rookie
    May 3, 2005
    2,914
    In front of you
    Here's another possibility granted I run a standard 6-speed.
    About 2-3 times over the past year, I had a problem with the clutch pedal returning from the floor. It would come up, but, it was sticky, it wouldn't come up with my foot. Naturally, the clutch would not fully engage. The couple of times this happened, I would press and release the clutch a few times, maybe up to 10 times until it felt normal again and it would run normal for months ... something was binding. Last weekend, my pedal got hard. It would go to the floor and return, but would not engage until almost near the top. I could shift normally through the gears, BUT, when I would tourque the car, the clutch would give and the revs jumped. Well, time for a new clutch ... but I don't have that many miles on the car ... less than 20k. When the tranny was pulled and clutch disassembled, there was plenty of clutch left on the plate. What we did find was, some of the wire type springs from around the throwout bearing had broken and were finding their way in between the pressure place and bearing. Oh well, we are replacing the clutch plate, throwout bearing and related seals and stuff. Also needed a new tranny mount bushing ... it was mush.
    Blah blah blah blah ....
    G
