CLUTCH OIL FOR F430 F1 | FerrariChat
Discussion in '360/430' started by MRF, Jul 4, 2019.
Tags:
  1. MRF
    MRF Rookie
    Jul 4, 2019
    2
    MICHAEL
    WHAT IS THE RECOMMENDED F430 CLUTCH OIL?
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Same thing they use for blinker fluid I think
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    Mobil 1 sync atf fluid
    Sent from my moto g(7) using Tapatalk
  5. tazandjan
    39,176
    Clutch oil is F1 fluid, so whatever your tech uses for the F1 system.
  6. MRF
    MRF Rookie
    Jul 4, 2019
    2
    MICHAEL
    Shell Spirex S4 HDX (Dex III) is what the dealers use but it is not readily available. I have seen some 5 gallon drums! Considering the car hold a liter of it and mine reservoir is at 10mm and the normal is 15 mm I don't need a lot. Are there compatible Dex III fluids to use?
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    As I mentioned above mobil 1 sync atf or you can stop at a dealer and have them top it off
  8. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Dex III is Dex III no matter who makes it.
  9. Jgivoo
    Jgivoo Formula Junior
    437
    New Jersey
    Michael,
    Sent you PM
    Joel
