Clutch question on 360 model | FerrariChat
Discussion in 'Technical Q&A' started by Schumi76, Feb 22, 2006.
  1. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    Guys,
    02, 360 Modena, 6 speed manual.
    Is there any way to tell on a manual trans. how much the clutch is worn ???
    Any indications while driving ??? Can the SD2 unit detect clutch wear on a manual transm. ??? Thanks !!!
  2. Rifledriver
    36,879
    No but you can kind of see it.
  3. Schumi76
    Feb 15, 2006
    329
    NC
    Marco
    Hehehe........
    you can kind of see it. How ???
  4. Rifledriver
    36,879
    Through the great big hole in the bottom of the bell housing.
  5. Schumi76
    Feb 15, 2006
    329
    NC
    Marco
    Oh ok.
    Thanks !!!
  6. Schumi76
    Feb 15, 2006
    329
    NC
    Marco
    Hehehe........
  7. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    Is this true for F-1's also, or just 6-speed manual ?
  8. Rifledriver
    36,879
    There are a variety of holes in the bell housing but even when you get a good direct look at the edge of the disc the actual difference between a brand new one and a worn out one is very small making eyeballing it almost impossible unless you have either seen many many of them for points of reference or you have a known worn out or brand new one to compare.
    Just do it the way we always have, drive it until it is worn out and have a new one installed. Prior to the much maligned F1 we couldn't do it any other way and everyone was alright with that.
  9. Hutch360
    Hutch360 Karting
    Jan 29, 2006
    121
    Shell Beach, Ca
    Steven Hutcherson
    I've been told to have car in 5th gear at 3500RPM's and push accelerator to the floor. If clutch is shot there will be slippage with a substantial decrease in acceleration.
  10. PAP 348
    Dec 10, 2005
    100,205
    Mount Isa, Australia
    Pap
    Another easier way is to pull the parkbrake on hard and put the car in 4th gear and slowly let out the clutch with around 2000RPM. If there is any sustantial wear in the clutch, the car will try to drive through the parkbrake. If the clutch is ok,the car will stall on you. And easy method we use to check suspicous worn clutches. :)
