360 - Clutch reading | FerrariChat
360 Clutch reading
Discussion in '360/430' started by joshtownsend, Sep 16, 2024.
  1. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    421
    H-town...TEXAS
    I am currently in the process of buying a 360 and wanted to check the clutch reading. I do not know how to read this in percentage. Can someone help me? I'm told its at 91%
    thanks
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,932
    Central NJ
    Dominick
    Understand that the data can be changed so it is hard to know for sure
    Get the clutch position from new to double check your clutch is 9 percent worn
    How many miles in this clutch ..about 5 k
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,567
    San Carlos, CA
    Mitchell Le
    All that says is ... that computer thinks the clutch is 9% worn in, or 91% of life remaining. At 25% life remaining, all hell breaks loose so that is a misnomer. Like Dom says, the 0% (clutch position at new) can be changed at will so you really have to guarranty. The better way is to look at the clutch plate under the car through the inspection port and measure its thickness and compare that to specification.
  4. joshtownsend
    Jul 12, 2007
    421
    H-town...TEXAS
    great info. Thanks guys!!
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,932
    Central NJ
    Dominick
    How.many miles in clutch ? That is usually a good gauge
