Clutch release bearing F355 | FerrariChat
Discussion in '348/355' started by Nike, Mar 7, 2013.
  1. Nike
    Nike Rookie
    May 8, 2011
    41
    Stockholm
    Niklas
    Hi guys!
    I am about to change the clutch on my F355 and will use the Hill engineering release bearing. When I look at he websites that sell them it says that if you have the early support flange then you have to upgrade to the later type flange to be able to fit the release bearing. Does anyone here know if you can find out if you have the early or the later flange without taking the clutch apart first? My car is a Motronic 2,7 so one of the earlier cars.
    Rgds
    /Niklas
  2. Rifledriver
    37,099
    Replace both.
    The flanges have been known to fail as well.
  3. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    What actually fails on the flange?
  4. seemefixit
    seemefixit Rookie
    Apr 1, 2012
    35
    Montreal
    Joe
    #4 seemefixit, Mar 7, 2013
    I did one on a 95 355 and it worked just fine like you could see the spring are not perfectly straight but don't leak and works great. The flange on this one was in great shape no scuff marks on it the only thing the springs don't aline
  5. Rorie
    Rorie Formula Junior
    Oct 2, 2007
    459
    Toronto, Canada
    Perfect advice. I did the same when I replaced my release bearing. You have the clutch apart anyway, so why not do it.
    R
  6. ahmadani
    ahmadani Rookie
    Aug 27, 2020
    16
    Kuwait
    ahmad awadh
    How can I buy this bearing part from where ??
  7. Qavion
    Qavion F1 World Champ
    14,287
    Ian Riddell
  8. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
  9. GatedF355GTB
    GatedF355GTB Karting
    227
    SF Bay Area
    Joe
    Superformance has them as well.
  10. Klas
    Klas Formula Junior
    Mar 17, 2014
    364
    Gothenburg, Sweden
    Klas Nilsson
    I did the same job a few years ago with Hill Engineering parts. It was quite easy as the clutch is in the rear end of the gearbox and worked really fine since then.
