430 - CLUTCH REMAINING? | FerrariChat
430 CLUTCH REMAINING?
Discussion in '360/430' started by Extreme1, Jul 27, 2020.
  1. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,212
    Santa Clarita, CA
    Can anyone tell how much clutch is left from this pic? When I bought the car it supposedly had 73% left. Can someone point out which is the clutch material in the picture please?
    The car has 12,700 miles on it. Image Unavailable, Please Login
  2. brogenville
    brogenville Formula 3
    2,004
    Robin
    See below the friction plate- its effectively a sandwich made up of a solid plate with organic friction material on either side that wears as the clutch slips.
    Workshop manual should have info on original and minimum thickness.
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,212
    Santa Clarita, CA
  4. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    514
    Based off that pic mine is looking pretty healthy.
  5. jag-oo-r
    jag-oo-r Formula Junior
    423
    Let us know what you find out! I'd love some external, empirical, physical verification that my X431 is reading correctly.
    Do I understand though, that the PP or FW are not flat, but are in fact convex, and so the friction plate is less-likely to wear on the outer-edge?
  6. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    They’re tapered concave so more likely to wear from the outer edge towards the centre.
    jag-oo-r likes this.
  7. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
  8. jag-oo-r
    423
    Ok! Good to know!
    It looks like in the images you're showing a thickness of 7.25mm - 8.16mm. What's the measurement on a NEW disc? And what thickness is considered "100% wear"? Sorry, this has probably all been addressed elsewhere; I admit I haven't searched. I'm just following this thread.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,561
    Central NJ
    Dominick
    #9 flash32, Jul 28, 2020
    Wsm says 5.95 mm for each side disk
    Which doesn't make sense compared to the measurement
    I think the pic will help Image Unavailable, Please Login
    Sent from my moto g(7) using Tapatalk
  10. CoreyNJ
    CoreyNJ Formula 3
    2,002
    New Jersey Shore
    I thought 5.6mm was the number is that not the case? That's the value I have been using in my clutch wear calculation formula.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,561
    Central NJ
    Dominick
    Probably because not under load ..or a different vehicle in pic ???
