Hi guys, I am needing to replace my clutch shortly on my CS Does anyone have recommendations to whether I replace with a stock clutch or aftermarket clutch? Also would you replace sensors etc also when replacing the clutch?
As long as your plates are straight standard is fine . It has last this amount off time . H&R rebuild what you have just let them know what material you want .
Well launching causes great wear on the clutch so if there was something better than can handle this then it would be better.
I'm sure H&R could give you proper recommendations . I've read on the forum that some time there's an issue using kevlar with F1 .
